Ooh, Magic Chef parts can be hard to get.... Try SearsPartsDirect.com or RepairClinic.com. Otherwise, you will have to contact MagicChef, but they won't sell parts like that to consumers....
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
SOURCE: Changing light bulb in microwave oven
If
there's no obvious removable cover over the bulb (and the owner's
manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic
Chef / Ewave see here or their contact page.
For Magic Chef
in Canada call 866.587.2002
We're
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
best checked by substitution.
Hope that helps.
Check
Hope that helps.
