Question about Kenmore 46462 Front Load Washer
Brand new kenmore HE2 front load washer - keeps filling
We were able to wash our first load of laundry just fine but during the second load the washer kept filling with water, even during the drain and spin cycles. At the end of the wash the machine shut off but water was still pouring into the machine. I was able to open the door but obviously water started pouring out so I couldn't get my clothes out. We've tried to do just the Drain/Spin cycle two separate times but it still fills with water during the whole cycle. What is the problem?
  • 5,911 Answers
Either your pressure switch is bad, or the air line that connects to the presuure switch has come loose. The pressure switch is located on the right-hand side rear of the washer with the top cover removed. It is a brown colored, disk shaped, device with an electrical connection and an air hose connection. Sometimes this hose comes loose in shipping, or the electrical connection may be loose. Without it, the washer will continue to fill and will NOT shut off. Now...if you just purchased this unit, DO NOT do anything that will void the manufacturer's warranty. It may be an inconvenience, but I would recommend you get the appliance repairman to come in and take a look at it. That won't be held liable if something were to break. This is, however, usually a simple problem and not considered major. I hope this reassures you some. Post back with comments if you have any further questions/concerns.
Posted on Jan 28, 2008
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Magkakatuluyan ba kami ni shelumiel
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
I heard my Maytag Neptune shake hard today when a load of laundry was going. I assumed the spin cyle got got offline for a second. The washer seemed fine. Then I did another load of laundry. While it...
do NOT call the Blue guys from Sears,,,he told me it would cost more than $2000 to fix a machine that will wash but not spin or drain ( I could get it to do both by pushing certain buttons). It is now outside and I have a used $215 washer that is doing great.
Nov 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Aug 23, 2009 | Kenmore 44102 Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 46462 Front Load Washer Logo
116 people viewed this question
Sal De
 Brian Main
Brian Main
