My 94 Escort had a problem with the fan relay connections at the relay, I had to remove it and the wires connected to it from the distribution box, this is complicated and not normal, but to check your relay, you will find it in the distribution box on the left fender close to the front underhood. The temp sensor is located in the steel portion of the heater line bolted to the block at the back of the cylinder head under the intake tube, there are two sensors there one for the guage and the other for the fan relay. Hope this helps, let me know
Check and replace the fan relay
What exactly do you mean comes on late? As in temperature gauge is up past normal operating temperature before it comes on?
