Question about HP OfficeJet 6210 All-In-One InkJet Printer
Hp office jet 6210
For some reason, mine will not print color. i have checked every setting and the color cartridge is full. in fact, i have 2 of these and both now have the same problem.
  • 8 more comments
  • Anonymous Nov 11, 2007
    my printer won't print and I don't have a disk an I forgot what website to go under to set up to make the all in one work again
  • MIZZNINI Nov 19, 2007
    MY ALL IN ONE HP 6210 WILL NOT ACCEPT CARTRIDGE BEEN GOING ON FOR MOTHS THE BUTTON JUST FLASHES AND THE SCREEN SAYS REMOVE AND CHECK COLOR CARTIRDGE! I AM USING A REFILLED CARTRIDGE!
  • dottie362 Dec 31, 2007
    I too have two 6210's with the same color printing problem. When the first one stopped printing in color I contacted HP and they e-mailed me some fix-it solutions such as performing a tap test which worked but had to be performed each time I wanted to print something in color. That became tiresome so I went on ebay and won another 6210 and wouldn't you know it this one has a similar problem also. It prints in color but the color is weak and has some line thoughout it. Is there a recall on this printer?
  • jsb007 Mar 11, 2008
    6210 won't print in color. I've replaced the cartridge 3 times.
  • Anonymous Mar 25, 2008
  • Anonymous Mar 30, 2008
    will not printe
  • andrew937 Apr 09, 2008
    I cannot print in color either. When It did work the color was mostly pink. I am very disappointed because I paid a lot of money for this printer.
  • Reb395 Apr 12, 2008
    My printer won't print in yellow, green and blue and the cartridge is new. what do i do?
  • Anonymous May 02, 2008
    Printer will not print color. Already replaced color ink cartridge with a new one with no success.
  • wiheho Nov 21, 2008
    6210 won't print in color in any mode
  • 72 Answers
Check the manual how can you make a test page without a computer. If its work you have software problem only.
If its not check the electrical contact on the cartridge bay, maybe you have to clean it from the ink.
Posted on Nov 11, 2007
  • HP Master
  • 1,113 Answers
Got to be Cartridge, print head within this cartridge that is full, is block/busted,
How do I fix a new color cartridge for an HP Office Jet 6210 All in One Copier
switched off the printer and put out the cartridge and again put it at its perfect slot/position and switched on the printer and press down the reset button for 10secs . then it will ask for print out for check the color. then it will b all ok.
thnx
Aug 25, 2012 | HP OfficeJet 6210 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Can the ink cartridge HP 98 work on a 6210 HP Office jet?
No, it can't
The HP OfficeJet 6210 works with the following print cartridges:
Black: 94
Color: 95, 97
Photo: 99
Source: http://www.shopping.hp.com/supmodel/product/Q5801A
TechSaver!
Feb 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can I disable the color? It's empty but black is full
even if it is empty, most printers require that you have the color cartridge installed. you have to go into the printer settings and change it there to print only black copy.
Sep 18, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Use of 852 and 855 cartridge in hp 6210 officejet printer
This quite often happens with CLONE cartridges and happens very infrequent with original cartridges.
The cause is the ink level chip used in clones is quite often a very cheap chinese copy and very prone to failure or misalignment
Either way take them back and get them changed is my advice
Aug 17, 2009 | HP Office Equipment & Supplies
Trying to put back in the color ink cartridge for 6210
The printers are bad about damaging the ribbon cable inside the print cartridge when you replace the ink cartridge. There is a small wire spring that gets pushed through the cable rendering the printer useless. Poor design by HP. How do I know? I did it to mine. It's cheaper to buy a new one then to have it repaired.
Jul 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Deskjet 5740 printer won't print in color.
did you check the printer properties on the computer side?
take off of gray scale I believe this may be the reason
Jun 10, 2009 | HP DeskJet 5740 InkJet Photo Printer
WHAT SETTING DO I NEED MY PRINTER PREFERENCES NEED TO BE ON TO PRINT A 51/2 X 41/4 NOTE CARD FOR A HP OFFICE JET 6210?
We need to manually set the size to print on the card size, go to HP Director or HP Solution center then settings >> print settings >> printer settings and manually set the size and then print.
May 22, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
770 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
