Spectroniq PD-1100 DVD Player
Problem for Spectroniq PD-1100 DVD Player
Divided picture on Protron PD-800 DVD/CD/CD-R PLAYER
By angelhound on Nov 11, 2007
I have a divided picture on DVD's (Same picture on the right and on the left side of the screen, elongated vertically to fill the screen. I have no color. Just black and white. I tried to change cables, but it didn't work. In the manual they list as troubleshooting a "divided picture", stating that "the unit is controlled by a microcomputer which may need to be reset. Turn off the unit's power, wait several seconds, then turn it on"  I've tried this also but it didn't work. Can you help me? Thanks
Alberto Ozzimo
Comments:
Nov 11, 2007
- ¡Thank you! You found the (so easy) solution.
Clarification Request
Posted by vclevidence on Jan 05, 2009
I have a very similar issue - but when I hit p-scan, it changes the issue from horizontal split-screen to a vertical split-screen. It really acts like it needs horizontal adjustment.
Same Problem
May 24, 2009
-   Thank you! Almost two years after this post and a different model, but same problem and similar solution; I had no PS or PScan button, but I had a reset button on the remove and VOILA! Back to normal - now, when the kitties are on the couch and walking on remotes, at least I know what to do to fix the DVD picture now.
Bravo! -   shutch08
May 24, 2009
Bravo! -   Guest
May 24, 2009
-   Thank you! Almost two years after this post and possibly a different model there is no model # at all listed, but same problem and similar solution; I had no PS or PScan button, but I had a reset button on the remove and VOILA! Back to normal - now, when the kitties are on the couch and walking on remotes, at least I know what to do to fix the DVD picture now.
Bravo! -   Guest
May 08, 2009
-   i have divided picture and no sound on spectroniq pd1100 dvd player
-   rachel_el99
Best Solution
posted on Nov 11, 2007
Very Helpful)
Benimur
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 3925 votes
Hi Alberto,
The split screen (identical display left & right) indicates that your DVD is on Progressive Scan.
P scan refers to progressive scanning mode and is not an indication of something broken but rather is a feature. What you can do is look over your remote and check if it's got a PS or PScan button. Pressing the button should revert to the single display. If there is no such button, pls check your menu or settings and should be there somewhere. At other times, there is a small hard switch at the rear (or front) of the player itself just for this purpose.
On your concern for no color, determine the color system of the disc you're playing, the setting of your DVD player as well as the color system of your TV. They should be the same. The 3 systems are NTSC, PAl and SECAM.
Hope this be of some help/idea. Pls post back should you have other concerns.
Good luck and kind regards.
Comments:
Nov 26, 2007
- Hi again,
Appreciate the rating and glad to be of assistance.
Cheers.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Spectroniq PD-1100 DVD Player
Questions and Unsolved Problems for Spectroniq PD-1100 DVD Player
Do you recommend Spectroniq PD-1100 DVD Player?
Answer
Answer
pd-dvr100 no power up on display, dvd spins once when you plug AC cord into wall recptacle
Answer
i put a dvd in drive and the text reads "load"; however, nothing shows on screen and then... (More)
Answer
Won this dvd player and it did not come with a remote. How can I get one? Thanks.
Answer
i need instructions to hook it up its a spectron iq dvd player
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(704) 315-5981
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
