Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Knocked it over, now it doesn't work...
I accidentally knocked the unit over. Now, no power indicator lights, nothing works. Is there something I can to do fix this, or do I need to take it in for service?
  • handymenot Jul 17, 2008
    i accidentally pulled out the filter to clean it while the unit is on. after that, no lights come on and the unit is not working. i suspected fuse, but i don't know where it is located and have no manual. thanks in advance for help.
  • halfassacres Aug 25, 2008
    Unit was tipped over while in operation. Assumed the bulb was damaged and replaced it. Unit still does not work and none of the lights are working either. If there is a fuse, where is it located and what size is it?
    Any suggestions would be most helpful.
    Thank-you
    Becky
Make sure the front and rear panels are snapped into place. The unit will not operate unless everything is in place.
Posted on Jan 22, 2008
  • 72 Answers
Fuse, check the manual or service!
Posted on Nov 11, 2007
Unit stopped working
I have the same problem. Cleaned filters, lights were never on to indicate they needed to be cleaned but i cleaned them anyway. Tried resetting lights by holding 10 seconds and nothing.....
Aug 07, 2012 | Honeywell 50250-S True HEPA Air Purifier
I have just cleaned the unit and replaced the bulb and starter but the light doesn't work. Thought maybe a faulty bulb so I tried another one and still no luck
Is the replacement a used bulb? Yeah, it happens. Also it may not be turned exactly halfway, and not making a good connection. If everything else works, check the wiring to make sure nothing got corroded or came off. If nothing is found, you'll have to send it in. If you have a starter, there's no warrantee unless you bought it refurbished from a dealer.
Jun 25, 2011 | Ecoquest Fresh Air Air Purifier
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Flashing blue lights
toss it. learn from it. Use Consumer Guide or something similar. Thank god it fots down the incinerator duct.
Jul 28, 2009 | Sharper Image Professional Plus Ionic...
Will not start up??
there is only one other thing that i can think of that might work ifyou haven't done that yet. right above the timer button there is a small pin hole. that is your reset button. you need like a safety pin or something really small to go in that hole. hold it for about 3 seconds. take the pin out and the system should reset back to normal. sometimes when you clean the filters that happens. not every time but sometimes. Now if that doesn't work. i would call the manufacturer again so see if they have any other solutions or if they can send you one more. I do apologize for the inconvenience. I will keep looking for you to see if there is anything else that i can suggest but try that first.
Aug 26, 2008 | Bionaire BAP1500-U Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Replacement Filter
i do apologize for the inconvenience that your having with the product. The only other thing that i can suggest cause you already did the majority of the troubleshooting, is that there should be a small pin hole on the top of the unit. that's the reset. stick a small pin in there and hold for about 3 seconds and then the unit should be reset. if that doesn't work there is something internal that is going on. recheck the manual for the trouble shooting options as well.
Oct 14, 2007 | Bionaire BAP815B-U Air Purifier
Red light won't stay off
I do apologize for the inconvenience, the best way that i can tell you to fix the light is that there is a tiny pin hole on top of the unit. that's a reset button. you need a small needle or something that will fit in there. hold it down for about 3 seconds. your unit should reset. the light sometimes comes on with new filters cause it hasn't recognized that they are new yet. if that reset doens't work please let me know
Aug 17, 2007 | Bionaire BAP825-U Air Purifier
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
130 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
