Hi I'm interested in the fault codes you get on a Yamaha yzfr125/08
Http://www.manualslib.com/manual/614738/Yamaha-Yzf-R125.html?page=316
Here is a page with some codes. Have a look at other pages on the site for maybe more. Have a look at a forum regarding your bike,
SOURCE: transmision fault
You have a bent shift fork (or two). The bend in the fork will not move the slider gear properly and causes the lockup. Expensive to fix. The engine gets a complete tear-down in order to get to the gears and shift forks.
SOURCE: i have a 1986 yamaha virago 700 that wont run properly
2 things need to be done first start your bike get a can of wd40 after your bike is warm and running spray around the carb jointsall 4 of them if your engine changes rpms up or down you have a intake leak ether your carb joint gaskets or o-rings need replacing or your carb joints are old and need replacing. at this point wont hurt to have you carbs cleaned also
