Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
The cover of detergent dispenser does not open..
Our Kenmore 15254 6 months old, the cover of detergent dispenser does not open and detergent tabs stay's in the cup. What can it be? Thank you.
  • 5 more comments
  • Anonymous Dec 04, 2007
    I have a Kenmore Dishwasher Model number is 15255. The detergent dispenser will not release during the wash cycle. Please help!!!
  • beaty4nc Jan 27, 2008
    I have the same problem? Did you ever get an answer?
  • 7641 Jun 01, 2008
    The cover of detergent dispenser does not open on my dishwasher and Im wasting water and hot water re washing :-(
  • dave60565 Sep 20, 2008
    How do you get the spring back on?
  • Anonymous Jan 13, 2009
    the dispenser cover won't flip open.
  • justinerows Mar 21, 2009
    Our dishwasher does not complete a cycle, so that the drying doesn't begin and the door to the soap does not open. It starts normally and sometime in the first 30 minutes it just stops going and the lights blink.
  • Anonymous Mar 19, 2014
    The 2" gray handle came off of my detergent dispenser drawer for my Kenmore Elite Washer model #11047081600. The manual does not show how to re-attach it. Do you have a picture or instruction on how to re-attach it to the dispenser drawer.
It is most likely the flip spring...you need to be certain that the legs of the spring are inside the door edge and the spring does not swing freely...and there must be tension on the spring so that when the latch releases the door flips...you can also try this with an elastic, put the elastic inside the closed door and up around the drying solution knob, this will let the door flip open showing that the latch does work
Posted on May 09, 2008
Kenmore front load washing machine leaking water from under the the detergent dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again. If the dispenser still leaks, then I recommend calling a service technician to diagnose and fix this problem.
May 01, 2012 | Kenmore Washing Machines
Rough film on dishes
first clean dw use tang then prime sink and run dw after that cut back on detergant
Jun 06, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 48102 Front load washer won't siphon out laundry detergent.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore Energy Star 44092 Front Load...
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Water over flowing from the detergent dispensers
Jun 18, 2009 | Kenmore HE2 Plus Front Load Washer
Detergent dispenser clogged-Kenmore 90 series washer
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 16, 2009 | Kenmore 24902 Top Load Washer
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Detergent Fill Dispenser
It may be gummed up inside with old detergent that has caked on . Try rinsing out the despencer until it opens and closes easy. DFD
Apr 22, 2009 | Dishwashers
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
Mar 20, 2008 | Kenmore 24 in. 16534 Built-in Dishwasher
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
313 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
