SOURCE: Ativa SPL 1506X not working
I had the same "click" noise when trying to shred. I had a Staples replacement guarantee (extended warranty) so I called them up and described the issue. They are sending me a gift card for the purchase amount. Seeing as they did not want the original unit back I decided to take it apart to see if I could find the problem. I did not find an issue with the gear as the other user stated but I did notice a burn mark on the circuit board just under the relay (which could make a click noise) I removed and inspected the relay (desoldered), but I could not see anything wrong with it so I re-soldered it back onto the board and re-soldered (re-flowed) all of the other connections just in case there was a cracked joint. Upon testing the shredder still has the same "click" sound. My guess is there is a faulty device on the circuit board such as a resistor or relay. To sum it up, to repair this particular issue you will be unable to implement a "simple" fix and it would realistically require either a new circuit board or a whole new shredder.
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Apparently you can'tget parts for this unit. My unit has a stripped gear and these people apparently think it is better to protect their repair facility than to accomodate their customers, In short they refused to send a replacement gear citing some nonsence about liability in case the customer should sustain injury while repairing the unit. This is of course, absurd, considering that I can buy parts for my Ford Truck with no such argument being presented.Therefore it is probably better to trash the unit and buy a new unit from a more considerate manufacturer. That is what I'm going to do.
