SOURCE: How do I change a rear wiper blade on a 2004 Toyota Sienna
You gotta flip the wiper arm up, and turn the blade out. Underneath you will find a tab in the center. Press in on this tab and slide the blade out.
SOURCE: rear wiper blades
the best way is to have the wipers pointing up. turn the wiper switch on low with the key off, then turn the key on till the wipers point up then quickly turn the key back off. now you can pull the arm/blade away from the window (the wiper will be flopping around a little) at the end of the arm, the metal curves down to make a kind of hook. at the end of the hook is a little tab. push the tab in and this allows the wiper blade to slide off the hook. its off
SOURCE: how to replace wiper toyota camry
go too your nearest auto zone and ask for wiper blades for a toyota camry and now got too your car pick up the mechnical arms then turn the upside down now u pull the rubber squeege out then relpace with the new wiper.
SOURCE: how do you remove the wiper arms to replace wiper
Take it to a parts store they will do it for free, there is a U shaped device that you have to move in order to get them off, and I don't know if your replacing the blade or the wiper assembly they are different. You should replace the assembly as they were out over time and will not clean the whole mirror.
SOURCE: Replacing rear wiper blade
I purchased a Trico "Exact Fit" #12-A rear wiper blade at Advance Auto Parts for my 2006 RAV4. The directions are very clear. It took about 3 minutes. The key is to open the plastic cover at the bottom joint of the blade by spreading the both sides with your index fingers and pulling straight out. This opens the cover and allows you to bring the blade to a 90 degree angle.
