The dispenser often has a small amount of water in it after a completed cycle so that's nothing to worry about. A lot of water usually means the dispenser needs a good clean. Pull the dispenser as far as it will go and then give a sharp tug to pull it completely out. The middle dispenser cover can then be taken out and cleaned, and so can all the other parts you've removed. The pipes in the machine and in the dispenser tray should be cleaned out well, as these usually cause the problem of retaining water. Put the cover back on the centre section securely and then push the whole tray back into the machine gently. Good luck!
