Question about Breadman TR2200C Ultimate Bread Maker
Power won't turn on
There was a power outage, then about 1 1/2 hours later the power came back on --- and now the machine seems to be out of commission. I checked the outlet with another appliance, and the outlet works fine. But when I plug in the breadmaker, nothing happens. Has a power surge destroyed my breadmaker? Nothing else in the house seems to have been affected.
  • Anonymous Nov 12, 2007
    I also have this same model and have tested the plug. Machine acts completely dead when plugged in and yet there is no damage to plug cord or machine. Not sure if this was the result of a power outage but could have been since we live out in the country and have those often
  • pookieram Jan 10, 2008
    After my bread machine stopped working after the power outage, I left it plugged in, even though there was no sign of it working at all. After about 3 weeks or so it suddenly came on, beeped, and has been working perfectly since. A friend had the idea that perhaps something with an internal back-up battery. So if your machine stops working, just leave it plugged it and wait!
    Problem Solver:
  • 6 Answers
The microprocessor in the keypad probably needs to be reset. With the unit unplugged, remove the keypad housing (one screw in back, one on the left side, rock it up enough to get a small screwdriver inside, then push back the soft plastic fingers to release the housing -- force it a bit, you won't break it). You do not need to remove the bottom cover.
Remove the keypad cover (4 screws) and the PC board (one screw). You'll see a factory reset button near the middle of the left side. Press and hold that for a couple of seconds.
If you want to test the unit before re-assembly, hold the PC board so it doesn't short against anything (there's nothing more than 5v on the board, so you won't get shocked), and plug the unit in. The display should appear. Unplug the unit, re-assemble, and then bake some bread!
There is also the possibility that the backup battery on this PC board is bad. Check it with a voltmeter -- it should be about 5v.
Posted on Jan 26, 2008
Our Breadman Ultimate will mix and kneed the bread but will not bake the loaf. Lynn Keyes
Posted on Jan 10, 2008
I had the same problem. I unplugged it for about 2 weeks and it started to work again. I don't know if it had to reset or what. I did the same things with checking the outlet. I can't explain why it started to work. The only thing is that now my select button doesn't work. I can only make the white bread. All the other buttons do work.
Good luck,
Posted on Dec 31, 2007
How do I fix my panasonic vierra that won't come on after a power outage?
Pull the plug and with the power disconnected hold the power button on for 60 seconds. After at least the 60 seconds plug the tv in and try to start it. If it works great if not , hold the power button in the on position for a count of 20 with the tv plugged in . If theres still no Joy try power with one of your volume buttons at the same time . One of these should provide a hard reset for the tv.
SOLVED 50 panasonic Viera model no TC P50C2 won turn on red light blinks...
Jan 26, 2018 | Televison & Video
Whirlpool WRF560SEYB Refrigerator did not turn back on after power outage, display said "cooling off"
Sounds like you had a power outage?-- did the lights go dim for a few minutes, before the power actually went out?-- Sometimes, low voltage will cause the compressor motor to over heat-- so it might have to 'cool down'-- What happened next?-- Did you try it again an hour or so later/-- Tell us more-- Mack B
Nov 03, 2013 | Whirlpool WRF560SEYB 30" french door...
After a power outage my tv will not turn off and the screen is completly black
With a power outage - power surge - anything is possible. One or more board s could be bad. If you have insurence you might be able to get a servicer to say that it was a surge and your insurence compaony will replace your set.
Mar 15, 2013 | RCA L32WD22 32 in. LCD HDTV
We a Kenmore Elite clothes dryer (Model # 110 70972990). Monday there was a power outage that happened while the dryer was running. Hours later when the power was back on, we tried to finish drying, but...
There is a thermal fuse. If your lint filter is on top of the machine it is in the rear of the machine behind the removable panal near the exhaust port. If the filter is in the door the fuse is behind the kick plate on the top of the blower housing they are usually white plastic. But a power outage won't blow the fuse
Oct 19, 2011 | Kenmore Dryers
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
Feb 17, 2011 | IBM System x3200 M2 Server
Had a power outage for several hours. Power came back on but the printer came on with all lights blinking. Turned power off and back on but the same problem. What's happened, and what do I do?
Nearly all later printers have circuits that stay 'alive' even with the power turned off. Try pulling the AC plug overnight' this should clear most stored errors that may still be present.
Jan 01, 2011 | Brother HL 5250DN Laser Printer
How do I set timer
manual for HB51RC
See timer at Amazon
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Rotate selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Dec 14, 2010 | Intermatic Outdoor Timer/Photo Control...
Sound quality has diminished after power outage
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
Apr 14, 2010 | LG RZ-37LZ30 37 in. LCD Television
Breadman TR2200C Ultimate Bread Maker Logo
182 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
