Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Perfect Focus Not Working- Picture is Blurred
  • I tried the same: mute>183
  • When I hold down the 'enter/menu' nothing happens...I don't get any 'data' information and it doesn't get clear
  • How long does that have to be held?
  • Perfect Focus Button goes through cycles, but doesn't reach 100%
  • When turned off and then back on....still blurred picture.
  • spiff68 Nov 13, 2007
    I have a similar problem, it appears as though the convergence is off, I was able to adjust the red manually but I cannot adjust the blue at all. The convergence just went off instantly, one minute it was fine the next the colors were offset. I tried the Pfocus, it never gets any higher than 4%.
  • 4,402 Answers
· Samsung parts for convergance problem
Posted on Dec 18, 2007
Got new STK392-040 chips and picture is still distorted. Manual convergence still won't alligne all colors.
the 183 is entry into the tech menu===you need to test all the low value resistors around the convergence chips(only 6 or 8) and they will read low and a resistor with NO reading may be your problem.
Also these sets use a pico fuse going to each chip--either right with it or back at the source----know what a pico fuse looks like"
Mar 12, 2012 | Samsung HCM4216W 42" Rear Projection...
Convergence problem
Are you trying to adjust it in the customer menu?
There is a hidden tech menu where you adjust and SAVE THE ADJUSTMENTS.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} TOSHIBA CONVERGENCE ADJUSTMENTS
If it does not save you have a problem with either the convergence output chips or the part of the set that stores the adjusments.
If this helped you rate this solution as I do this here for free.
Dec 10, 2009 | Toshiba 57H83 57" Rear Projection HDTV
The picture is blurred because the red, green, and blue colors are not properly focused. The TV's auto focus feature doesn't solve the problem
This can be as simple as poor solder connections at the convergence ICs or defective ICs. If you can solder you can fiz this yourself. Let me know if you wish to attempt the repair and I'll suply additional details and instructions.
Mar 23, 2009 | Sony KP-43HT20 43" Rear Projection...
Every picture I take is blurred
Try to reset your camera.
Press Menu.
Go to Set Up.
Go to Reset.
Select Yes.
Press Menu.
Dec 16, 2008 | Samsung Digimax D53 Digital Camera
Perfect focus not working
I purchased mine about 5 months ago. Ive been researching and playing around with the remote. This will help you on the way. With the set off, press "Mute", 1, 8, 2 then turn the tv on. This will bring up the main settings, dont change any values on any page, unless you write the origonal values down first, because the total reset doesnt return everything to a "factory" preset. Scroll down to reset and press the enter key. I havent come across any owners or service manuals, and support is slim to none. I wrote a review for the same model on a wal-mart site I believe, and it explains adjustments in more detail. If you want to try to figure out the buttons for yourself, while the tv is on, press "Mute 1, 8, 3" this is another set of adjustments for finer detail. If you change an adjustment here and your not sure, just press the exit button. To save your adjustments in the convergence mode, press and hold the enter button, it should flash a few times and center itself on the screen. If you make a mistake in this mode, the total reset I mentioned first should get you back on track. If you find anything out or have a question, feel free to write me at
Jan 15, 2008 | Akai PT5598HD 55" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Perfect Focus not working
enter your service mode by pressing mute-1-8-3- a cross hatch pattern should apear,when it does and it looks alright press and hold the enter key the ,it will say data write then press the focus key the set will align your sensors and retuen to the cross hatch pattern ,tune off set and turn back on and try the magic focus ,should work.
Sep 13, 2007 | Samsung HCN4226W 42" Rear Projection...
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Wavy picture with a lot of red, perfect focus states no sensor data
Convergence ic's need to be replaced. If you pay over 300 bucks your getting ripped! Good Luck
Aug 26, 2006 | Akai PTH5498 54" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
