Question about Sony DAV-DZ100 System
Problem playing CDs
I've got a sony dav-dz100 for 6months now - everything works fine except the fact that it won't play Cds any more. It plays dvds without any problem but i've tried many audio cds (that i used to listen on that home theatre) without great success. I can hear it spinning but it says 'Cannot play' after some time. thanks for any response
Re: Problem playing CDs
Did you put the firmware update, perhaps it can solve the problem
Posted on Jan 01, 2008
0 characters
3 Points
Davaz900kw sony
cd's use a different laser than dvd's when playing. You would need to have the optical pickup replaced.
Jan 10, 2013 | Sony DAV-DZ100 System
I have a (jvc dvd digital cinema system th-s3). that will not play original dvds however it seems to play copies and cds just fine in fact all other functions work correctly. i have tried a lens cleaning...
I have the same system. I've had no trouble until a year ago, then the system got particular about when it wanted to play DVDs. I've also used lens cleaner to no avail. It plays some DVD's but plays all CD's and some copies. It has given me good service but cost me a lot of money. I hope there is a simple solution to this.
May 17, 2011 | JVC TH-S3 System
I got an Sony HCD S 300 Home Theater set recently. As I put in dvds and cds for playing, the dvd player says NO DISK. Thinking it is because it is not a original dvd it isn't working, I put another DVD...
It could be down to the Region of the Player or the Laser is Failing. As it doesn't play CDs then I suspect the the Laser is Failing (almost failed if it plays a cleaner but not CDs).
May 05, 2011 | Sony DAV-S300 System
Our Sony c 770 no longer plays DVDs or Cds but it still works as a receiver. Can we connect a DVD player to it and have it come thru the 5.1 speaker system?
Yes, tis unit has 2 video inputs at rear so you can connect any other dvd player sound (analog or digital) to get 5.1 channel surround sound from DAV-C770 speakers.
Click Sony Support to download user manual copy of DAV-C770 that has more details about connection setup.
Hope this info will help you.
Nov 26, 2010 | Sony DAV-C770 System
Sony DAV-BC150 System
I have this same problem. Plays music CDs fine but DVDs do not work. It recognises the DVD tries 3 times to play it displaying "Reading" and then moves on to the next available disk. Any suggestions?
Mar 20, 2008 | Sony DAV-BC150 System
Sony DAV SB100 home theatre DVD / CD problem
Grating adjustment is off, Compounded by dirt on the secondary lenses...accordianman
Feb 19, 2008 | Sony DAV-SB100 System
Not being able to play burnt dvds or cds
you have to make sure your player supports the format your using on the dvds/cds.possible formats iso,avi,mp3,mp4 ect ect
Dec 30, 2007 | RCA RTD155 System
Samsung HT-P38 won't play DVDs but plays CDs just fine
I called Samsung. They told me how to do a software reset and solve the problem
1. Take out all CDS.
2. Turn off and then on.
3. HOld down stop for 5 - seconds.
Problem Solved!
Apr 11, 2007 | Samsung HT-P38 System
Dvd always says no disc
i had this problem for copied dvds and cds and badley scratched ones when renting. never had the problem with genuine products. it seems to be able to dectect snide dvds but my 20 quid jobby in the bedroom will play them all !!!!!!
Sep 29, 2006 | Sony DAV-S400 System
No color
is the dvd menu in color ? if so it could be in the video process circuit if not try different video cables.
Jun 11, 2006 | Sony DAV-C450 System
Sony DAV-DZ100 System Logo
150 people viewed this question
Top Sony Home Theater Systems Experts
Dennis McCollum
Electro Med Services...
Are you a Sony Home Theater System Expert? Answer questions, earn points and help others
