Televison & Video Logo
A
Anonymous Posted on Oct 15, 2014
Why does my tv not c/o when I shut off my sky box
john sturdivant
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Oct 26, 2014
 john sturdivant
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
10950
Points
22
You should have splurged for the 'Smart TV.'
1helpful
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
1helpful
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
1helpful
WHAT SKY BOX CAN I USE WITH A KV-28LS35U SONY IN SPAIN
Your TV has a SCART socket. So you can use anything from a plain "receive only" Sky box through to the recording HD boxes. As long as the box also has a SCART socket then the TV and box can be connected.
If you take a box abroad with you to leave there permanently then you'll need to think about what kind of contract (if any) you want. A Sky box without a viewing card will let you watch a broadly similar range of channels to Freeview in the UK. There's a useful comparison guide here: http://www.ukfree.tv/allchannels.php
Used Sky boxes are available cheap from Gum and the Facebook selling pages, or have a look in your local classifieds.
If you buy a recorder box, remember that the recording and Live Pause features are only available with a Sky subscription. They don't work with an expired viewing card or no viewing card at all. If you think you'd like to record programmes while abroad then consider a Freesat PVR instead. It will cost more in the short term, but you will have the same kind of functions as a Sky recorder box.
One other option is TV via the net. There's a device called Slingbox. It uses the internet to port your home's Sky box signal to you somewhere else in the world. You don't bother with a second Sky box, just add a Slingbox digitiser to the home Sky box and connect it to your internet service. In Spain, you have a Slingbox receiver connected to the internet and your TV. What you've then got is control of the UK Sky box, and those signals sent to you in Spain via a web connection. You operate the Sky box in the same way you would at home. The difference is that the TV is 1500 miles away.
Slingbox relies on you having a decent internet service in Spain. That might not be practical, or possible, or even desirable. But if you want to have your full Sky package in a second location without forking out for a whole year's subscription then it is one solution that wiorks.
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Venturer Tv to Sky
It sounds like your TV is on the wrong input. Look for a button that says input or source. Depending on the TV this will either provide an onscreen menu to select an input or it will simply scroll through the inputs. Turn on the Sky box and run through the inputs until you see something that looks like your Sky Box.
TV locks up the SKYdigibox
unplug tv for 1 mins,re-plug it back in!
Sky + box and Akura 37'' television
with your tv swiched on, Turn your sky box off then keep your finger on the backup button whilst turning your box back on, make sure you keep your finger on backup button until all the lights come on on the front of your sky box, or a message comes on screen (tv) saying "UPDATING SYSTEM SOFTWARE, DO NOT DISCONNECT FROM THE MAINS, THIS WILL TAKE APPROX 10 MINS"
if this does not help give me a bell on 07738910264 after 330pm mon-fri
2helpful
Sky upstairs
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
