When cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Hi pete ingraham, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Is the feed roller running?
the front feeder roller seem to be jam and the back one rotate about three turn
