possible
right click on the publisher 8 and then click on the properties tab
then click on compatibility tab and adjust to win 10
if there is no win 10 for compatibility, you may have to upgrade the version of publisher 8 or upgrade the driver for publisher 8
I suspect not since it was designed for windows XP, though will work with 7.
There's is another version designed to work with windows 8, but there's no guarantee that will work with 10. It seems some software used a component that was discontinued with any windows version 8.1. and onwards.
If f22 lightning 3 was written for an earlier version of Windows then you need to have Windows 8 run in that mode when you play the game. It is called compatibility mode.
Calendar Creator is not supported for Windows 8 at this time. Even the newest version which is 12 is not supported fo Windows 8. You could try running it in compatability mode however.
Right click the Icon and select "troubleshoot compatability"
Between Win95 and Windows 8 there are several other versions Win 98, Win 2000, Win XP, Vista, and Windows 7. Try to run the CD in compatibility mode. If it does not work you will have to forgo the use of that software or run it on an old machine, or upgrade to a version compatible with Windows 8 if one such upgrade exists.
What you need to do is run the driver setup in windows XP compatibility mode. Right click on the setup icon, select properties, compatibilities tab then select Windows XP SP3 (or some older version of Windows. Then left click on the "Change settings for all users" button and from the new window select again XP service pack 3 compatibility and check the "Run this program as an administrator". Click OK and then run the setup application. It worked for me on Windows 7 ultimate.
PhotoSharing is possible with Yahoo IM 8,9 and 10 About Webcam sharing, if you are using Yahoo 10 and other person is using yahoo 9 or 8, the Video call will not work since Yahoo 10 will check for version compatibility
you can bypass this by asking the other person to click on the option, View Webcam, this will initiate an invitation sent to you, you can accept it and the other person can see you. vice versa you can click on view webcam and the other person has to accept.
