Follow up to my Jun 02, 2008 post. We had a service tech come out
today, and it turned out that the door switch was bad. The
neutral side had continuity with the door shut, but the hot side was
sporadic. A new switch has been ordered.
According to the Frigidaire tech sheet attached to the door, which is
located beneath the control panel and behind the door skin, the problem
could potentially be a bad control panel also.
Hope this helps someone in the future!
If DYI, door switch contacts worth cleaning prior to replacing the switch. I used a nail slid up the notch in the contact housing to release it from the switch assy. Grease, gunk gets on the contacts. To replace the contact housing, make sure the switch assy is pushed to the "closed" position.
I'm haveing the same problem...
Does anyone know how to correct this problem? My dishwasher is only 3weeks old and just started acting up.
Our dishwasher is the same model with the same issue. It's just under a year old.
I have the same problem. My dishwasher is just under a year old.
