Machine fills with water cycle starts then stops and counts down reset to spin water discharges and drum turns to start spin then stops after a few minutes pump discharges more water but does not go into spin mode
cant see this button only hold rinse.when reset to spin water discharges and machine starts as if going into spin cycle but then stops.cant see this button only hold rinse.when reset to spin water discharges and machine starts as if going into spin cycle but then stops.
You can't post conmments that contain an email address.
If the motor is not spinning, you may have a burnt out motor or faulty Motor Control Board. Else, if the motor is spinning, fix the belt from the motor to the drum.
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
