Question about Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP66 50 in No Picture/Only Sound
My TV has no video, only audio. It's half a year old and have experienced no problems with it up to this point. I was just watching tv and it went completely blank...no noises, no pops, or buzzes. We still have audio and we've unplugged and reset every device attached to the tv itself. Right now we've just unplugged it and letting the poor thing "rest". Any suggestions?
Thanks
    Genius:
  • Toshiba Master
  • 1,689 Answers
Most likely a power supply failure, and or a failure on one of the other boards that is causing the shutdown.
The set will need service.
Jerry G.
Posted on Apr 30, 2008
My Toshiba model number 51H83 has picture but no sound. I put a dvd in and the sound worked but when I went back to TV no sound. I dusted the back of my tv yesterday and since then have had no sound. Tv is...
Are you using the rf antenna input for TV or 1 of the VIDEO inputs from a cable box or sat receiver. If the latter check to see if you unplugged the audio fron the box White and red wires from box. If thats ok Plug that dvd player into that input using the cabes from the dvd player .If you now have sound change ables from box. if still no sound cable box bad. If still no sound from that input check for solder connection on input jacks. If antenna input is used replace the tunner intv.
Mar 25, 2010 | Toshiba 51H83 51" Rear Projection...
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
I have an LG flat screen no picture or sound
As your TV is three years old, I would suggest you contact your LG dealer to arrange an engineer to call to do a software upgrade on the it. The current software will be out of date & if you are connected via the HDMI connector then this can give audio/video problems.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
No picture, good sound
It's most likely the video board. The menu is injected at the output of the video stream right before the LCD panel. Having audio indicates the signals are getting from the inputs through the input switcher and audio boards. Unless you have electronics experience, I suggest having an experienced tech look at it.
Apr 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture
Just increase the screen voltage slightly by turning the screen control on the LOT and if a horizontal line appears, check the vertical IC supply, and if everything is okay, change the vertical IC, it is not costly.
Jan 21, 2008 | Toshiba 32AF43 32" TV
Still posessed!
These tv does have loose of audio problems im concern about looseing picture . Try unplugging tv for 5 minutes it will reset tv very common fix for audio. Tv that are less then a year old are sometimes covered under new warr call manufacture on that.
There is a microprocessor on these that lockup and when you unplug it. it resets it.
I have a tv shop and have helped customers get exchanges under a year especially if you complain
good luck i hpe i helped Thanks DOCTOR VIDEO
Dec 31, 2007 | RCA 32V550T 32" TV
No picture
Most likely your tube is not bad but rather you have a loss of video. It's going to take a repair facility to find out the true cause of the loss of video though.
Jun 09, 2007 | RCA 35V432T 35" TV
Dark picture
you could be having a problem in your video circuit or your flyback transformer is bad have a tech look at it for repair.
Nov 13, 2006 | Toshiba 32A33 32" TV
Toshiba 50HP66 50 in. Plasma Television Logo
789 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
