I tried purging the lines. The red light on the unit that indicates compressor turns on but I still dont get any cold air. How can I or do I need to add r410a refrigerant to my air control ductless system? I have pressure in the lines and there are no leaks.
Comments:
Jul 05, 2009
- This system has never worked. It has never had to drain. I am beginning to think that the compressor is not running. It is a new system that was installed last year and it is still not working. I have all the equiptment needed to add r410a to it and it just seems to not **** any in when i connect it to the service port.
I would check the drain to see if it is stop up.Next check to see if the unit inside is freezing up.If it is check to see if fan is running and if fan is running the you proable have a freon leak. Low charge on freon will make it freeze up and the fan not running also.
Therefore I would request to add r410a refrigerant for better cooling.
Thanks for contacting Fixya.
Daikin reverse a/c will not turn on. first it flashed üS" in the program section Then...
(More)
Daikin reverse a/c will not turn on. first it flashed üS" in the program section Then I tripped the circuit breaker - now it has "VER 29.02"on the display and won't respond to any button presses. Dakin is **** technology. Give me a system that just turns on and ignores all the complex electronics.
hi, i have 2 daikin air conditioning unit, 1 is working perfectly but when the 2nd is turned on the...
(More)
hi, i have 2 daikin air conditioning unit, 1 is working perfectly but when the 2nd is turned on the power light just flashes and nothing happens, any ideas thanks.
Daikin unit displaying a message of Unit 0, the eye symbol and E3 The model is Daikin BRC1D61. The...
(More)
Daikin unit displaying a message of Unit 0, the eye symbol and E3 The model is Daikin BRC1D61. The operation light also flashes. What's wrong with it?
Daikin aircon just blinks green light and wont do anything, but will start working randomly if left...
(More)
Daikin aircon just blinks green light and wont do anything, but will start working randomly if left on.. no timer set, and responds to on/off on remote..
why does my daikin single split fan coil stop completely for about 30 sec and run again throughout...
(More)
why does my daikin single split fan coil stop completely for about 30 sec and run again throughout the night
