Question about Brother MFC-640CW All-In-One InkJet Printer
Wont work no pwer after a storm tried anither power outlet
  • Anonymous Jan 10, 2008
    No power after storm
  • Brother Master
  • 1,113 Answers
Main board has blown and it aint unussual for modem board to go as well, too expensive to repair.
Might be able to claim under your insurance if you have fusion cover.....
Posted on Nov 11, 2007
What is the problem, my Storm is plugged into the power supply and everything does not work until I start it up. When I turn it off, the lights and everything else works for a little while then sarts to...
Do you have power at the outlets? If you do but the lights keep going dim then your converter is going bad or has already failed. Your lights are 12v and the outlets are 100v. If you do not have power at the outlets then you need to check the transfer switch that toggles between generator power and shore power.
May 09, 2014 | Fleetwood 2014 Storm 28F
Philips 32PFL3505D 32 in LCD TV wont pwer on
Most likely you have a damaged power supply
Sep 01, 2012 | Philips Televison & Video
Wont turn on, unplug for a while, plug it in here the click then a lighter sounding one 1.5 to 2 seconds later, try pressing on and nothing.
Look for any loose contacts in power outlet. Try connecting the TV to another power outlet, which you are sure works well. If the TV is still in same condition, switch it off manually, switch off power, remove plug and wait for 48 hours and retry.
Aug 23, 2012 | Sony KDL32L5000 32 in. LCD HDTV
Bravia 40 inch wont turn on
Ensure there is power in the power outlet. Try connecting the TV to a different power outlet, where other devices do work. Look for jammed on/off switch on control panel or on remote. If nothing works, better refer it to a qualified service technician.
Jul 19, 2012 | Sony Televison & Video
Emerson tv lost the ability to power on after a storm
I would probably look at the internal fuse that protects the power supply inside the tv. The storm probably sent a power surge through your outlet, your breaker may not always work correctly, especially if the breaker is old. The fuse should be inline with the hot side of the AC power to the power supply circuit. You would have to open up the tv, but you would be able to spot the fuse very easily. Fuses are cheap, but getting to it may be a problem
Aug 20, 2009 | Emerson Televison & Video
Pwer wont come on...
try another power cord, and a known working power outlet. If no good, replace power board or get a new monitor. contact manufacturer to see if it's in warranty.
Aug 08, 2009 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Have power on main line but dryer won't run and light in tub doesn't work
check to make sure both sides of the outlet have pwer present, if not, repace outlet or correct wiring problem, as well check to see power cord hooked up correctly on dryer.
Jun 30, 2009 | Dryers
HP Pavilion will not power up
Yes pwer in entering since the LED lights up but most probably your SMPS orpower supply has fried due to a voltage surge. Try replacing the Power supply unit and see if there is any difference(use a working SMPS for trial and if this works, you have the solution...........sodeep
Mar 30, 2009 | Computers & Internet
Brother MFC-640CW All-In-One InkJet Printer Logo
41 people viewed this question
James Cagle
James Cagle
Jim Keysor
