Question about Kenmore 22422 Top Load Washer
Kenmore 70 water won't drain
Washer fills with water, but then the water won't drain. I've tried to restart the machine, but it won't re-set.
  • 2 more comments
  • Capo Beach Dec 01, 2007
    Kenmore Series 90 will not drain or spin. Water fills fine and runs through the normal wash cycle but then will not drain or spin. Any ideas on a self fix would be greatly appreciated.
  • Anonymous Dec 02, 2007
    water wont drain competely
  • JennieDeike Dec 13, 2007
    My washer fills up and agitates, but doesn't spin or drain. What can be the problem?
  • p od Dec 15, 2007
    When it is time to drain and spin, my machine just stops...The only thing that I can do is change the water setting, and more water enters the machine...but nothing after that....what gives?....It isnt the power supply...I used the same plug to have my shop-cav suck the water out...My model# is 244223
  • 126 Answers
Check your power supply. need more info!
Posted on Nov 23, 2007
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
My kenmore series 70 will not spin or drain the water out
open your washer put a screwdriver in the lid switch hole set the machine on spin tell me what happens be careful the tub should spin out the water
Apr 30, 2009 | Kenmore 23822 Top Load Washer
Kenmore series 70 will not fill
Ive only run across this a couple of times in my years of appliance repair. This sounds like you do not have an air gap on the drain hose. Where the hose hangs into the wall drain pipe make sure you do not have that sealed air tight with duct tape around it or something. It needs to have a gap all the way around the hose and just hang freely. If it is sealed off then it creates a siphon effect and sucks the water right out of the washer tub into the drain.. Hope this helps.. Thanks
Feb 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series washer
The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
Apr 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
57 people viewed this question
Sal De
 Brian Main
Brian Main
