Question about Kodak EasyShare C875 Digital Camera
Flash my camera Kodak easyshare C875 takes pictures all dark when i take pictures.But when i take pictures without flash it comes out lighter but blurry.How do i fix it?
    An expert whose answer gotĀ voted for 100 times.
  • 58 Answers
Re: flash
Checking on the first 2 comments, if there is flash and the pictures are dark - please check the lighting conditions
is it a dark place, fairly lighted or fully lighted
the flash also has a certain range, the subject may be far that the flash cannot reach it
if there is really no flash - it may be a hardware problem, pls contact kodak to arrange repairs
try going to PASM> fill flash too, if still not working - repairs =)
Posted on Feb 13, 2008
0 characters
3 Points
Kodak c875 digital camera: flash has stopped working and not able to take pictures in dark. flash on icon comes on screen but pictures are dark and no light flashes may be need to replace bulb but how and...
Replacing the flashtube is not something you can do. It requires complete disassembly of the camera and delicate soldering skills. It must be sent to an authorized Kodak repair facility. It will cost a lot.
Jul 15, 2011 | Kodak EasyShare C875 Digital Camera
If the flash is not comming on its ether a bad flash bulb or capacitor inside the unit or you do not have it set for flash, of course if you not in a well lite are without flash it would be inpossiable to get a lighter shot. I would suggest you have the camera looked at by a local camera shop it can be fixed.
Thanks hope this does help please do leave feedback and ratings for your free answer.
May 03, 2010 | Kodak EASYSHARE M1063 Digital Camera
Dark pictures with zoom and in low light
Your best bet is to increase the ISO setting to at least 800. Don't use flash unless you're within 10 feet. My idea if a new camera would be a DSLR. Expensive, has a learning curve, but the results would be spectacular.
Feb 19, 2010 | Kodak EasyShare C875 Digital Camera
Pictures taken inside are coming out dark and blury
Please readjust the ISO: Different SCN (If you're experiencing this problem with your low light pictures try and use SCN night, the logo shows a moon and a star, with or without Flash.
Jan 01, 2010 | Kodak EasyShare C875 Digital Camera
Picture too dark
Do not confuse dark pictures with black pictures.
1. Flash Range
2. Exposure Compensation
3. Monitor Calibration (low monitor brightness)
4. Obstructed or covered flash
5. Obstructed or covered light sensor (only on certain models)
6. Flash not firing
A normal sunny outdoor scene is a good way to test the exposure metering of the camera.
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Kodak es c875 flash problem
Try to do this press the flash button then chose the Fill Flash so if you take picture it will always fire the flash., May be your using the Auto Flash.
If your flash will not fire using the Fill Flash setup it means the Flash is defective call tech support toll free 1 800 235 6325 ext 12
You may also see the flash setting if you press the menu button and under menu button look for setup
Nov 15, 2009 | Kodak EasyShare C875 Digital Camera
Flash does not work, have good batterys
probably there's a problem with the bulb of the flash itself and the cam would need to be serviced, contact kodak for that
you can try this too
use lithium/ni-mh> powercycle (remove batt and card)> put back batt> turn to PASM> try fill flash (at the top of the cam, use flash button), flash button at the center part of the screen should be a plain lightnightning bolt, no A beside nor line across it
take a picture
if still no flash - arrange repair with kodak
1 800 235 6325
Nov 14, 2007 | Kodak EasyShare C875 Digital Camera
Sounds like the same problem as with the samsung digimax 401... Internal memory. Insert a memory stick and hopefully the camera will come back to life,no?
Oct 31, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
255 people viewed this question
Top Kodak Digital Cameras Experts
Are you a Kodak Digital Camera Expert? Answer questions, earn points and help others
