SOURCE: aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
SOURCE: Water leaking from washer
you most likely have a pump leaking post your email so i can send you the manual
SOURCE: he2 leaking from detergent dispensor
We had the same problem, It was a pair of sock stuck behind the seal in the drum blocking the water inlet to the drum. Like others we managed to get our fingers between the metal of the drum and the rubber seal near the detergent dispensor to remove the sock.
SOURCE: Amana washer model LW6501W2 leaks in front during fill up
It leaks
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
