Regarding your query, it sounds like the HP Officejet 4315 printer is locked into the advanced service test mode (i.e. one of your ink cartridges is causing the issue). Remove both ink cartridges and clean thoroughly before proceeding to next step - our Inkjet411 support links are provided below to help you diagnose the issue.
1) Clean cartridge/printer electrical contacts. Also inspect printer's internal carriage flex cables for surface damage (i.e. burn marks) or an uneven contact surface (by which the cartridge's rear electrical contacts mates with).
http://inkjet411.com/?page_id=1519
2) Perform either of the 'B' procedures below to verify HP Officejet 4315 printer and ink cartridge electrical performance.
B.1. Perform Tap 43 test: [for most older HP Officejet printer models with keypads]
1. Press * and # keys at same time
2. Enter 1234 (or 124). The 'Underware' menu should be displayed.
3. Using left/right arrow keys, navigate to Special Reports/Reports Menu (......or 'System Menu' / 'Information Menu' if Reports Menu is not available). Select Enter.
4. Using left/right arrow keys, navigate to 'Extended Self Test'.
5. Select Enter to print test print - evaluate test print. If excessive nozzles are missing from the stair step pattern, then perform cartridge cleaning to correct.
6. Using left/right arrow keys, navigate to 'print-mech button tap' menu.
7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. NOTE: enter 'code = 41' if 'code =43' does not activate the diagnostic print report.
8. Select Ok. Within one minute the Tap 43/41 diagnostic test pattern should be initiated and print. The test page prints.
--- Providing the color cartridge is partially functioning, the diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 21/27/56 black cartridge should display 416 good nozzles (26x16 grid), while a good HP 22/28/57/58 color ink cartridge should show 300 good nozzles (10x10 color grid). For reference, please refer to video at link below to help evaluate test pattern. [NOTE: HP 56/57/58 and HP21/22 cartridges are electrically similar]: http://inkjet411.com/?page_id=2358
B.2. Print Diagnostic Self-Test Page (only available on select HP printer models):
1. Press the Setup Button located on the bottom center of the control panel, beneath the LED readout.
2. Press 2 to select "Print Reports"
3. Press 6 to select "Self-Test Report" on the number keypad
4. Examine the resulting self-test page that prints. There should be lines extending all the way across the page in black, yellow, cyan and magenta. A missing black line indicates a problem with the black or photo cartridge. Faded, streaked or missing lines in the other colors indicates a problem with the color ink cartridge. Refer to video at link below to help evaluate test pattern.
For advanced HP inkjet printer diagnostics specific to your printer model, please refer to 'HP Diagnostics Tests' .pdf file at the following link: http://inkjet411.com/?page_id=1813
Please note that all Costco USA (all stores), Costco Canada/Mexico/UK (most stores), Fry's Electronics USA (all stores), Best Buy Canada (13 stores) support the the HP 61 ink cartridge series. Our network of retailers stand behind the product and performance - guaranteed. For store locations and details on ink refill pricing:
Costco USA Ink Refill Service (465+ stores):http://www.costcoinkjetrefill.com
Costco Canada Ink Refill Service (59 stores):http://www.ca.costcoinkjetrefill.com
Costco Mexico Ink Refill Service (35 stores):http://es.costcoinkjetrefill.com/
Costco United Kingdom (7 stores):http://uk.costcoinkjetrefill.com/
Fry's Electronics Ink Refill Service (34 stores):http://www.frys.com/ads/page51
Best Buy Canada (13 stores):www.geeksquad.ca/inkrefill/
We also have ink refilling centers in many University stores across the USA & Canada, including:
Brigham Young University, Brigham Young University - Idaho, Cornell University, New York University, Queen's University, San Diego State University, University of Calgary, University of San Diego, University of Virginia and University of Wisconsin - Madison
Refill Store Map Locator:http://www.go2ris.com/
Just bring your ink cartridges into any of our authorized refill center locations. The in-store representatives (at either Photo/Electronics support center) are trained to refill over 270 different ink cartridge types from all the major manufacturers (i.e. HP, Epson, Canon, Lexmark and Dell) and can answer any additional questions you may have. It typically takes less than an hour to complete the refill from the time you drop the cartridges off. Our network of retailers stand behind the product and performance - guaranteed. All of our inks are Made in America and closely match original manufacturer's ink quality - we are sure you'll be satisfied with both color 'pop' and image longevity performance.
The RIS InkCenter - the power behind retail Inkjet Cartridge Refill Services: http://www.youtube.com/watch?v=e7tlmEexor8
Save Money. Save The Environment.
Customers who have questions regarding the use of refilled ink cartridges can visithttp://www.inkjet411.comor contact us directly [email protected], if a refill center is not close to you and you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge fromhttp://www.inkplicity.com/as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
-Thank you
SOURCE: hp officejet 4315
There is no "print mode", Fax, Copy and Scan are modes one can enter, printing on the other hand is done when a print job is detected from your computer
DRIVERS to suit download link
Download Manual and Setup guide HERE
Please rate solution as fixed.
SOURCE: driver needed for hp officejet 4315
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=ca&dlc=en&product=1138342&lang=en&
Follow this link and select your operator system ( XP, Vista...)
Go to the driver section and download what you need !
SOURCE: Error 405
this usually happen when sending fax ,if thats the case take the following steps
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
hope this helps if you have further problem do let me know
SOURCE: My HP Officejet 4315 states Cartridge Error. Can
HP F2480
Align Cartridge:
If you have just installed a new cartridge it is recommended that you align it. Click on "Align" to align your new cartridge
SOURCE: my hp officejet 4315 says paper jam and will not
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
