Panasonic KX-P2023 Matrix Printer Logo
A
Anonymous Posted on Oct 14, 2014
Printer ribbom I have installed a new printer cartridge and I have adjusted the font settings to bold and the ink will not show up on the paper. Am I installing it improperly?
Chee Seng
Level 2:
  • Expert 284 Answers
  • Posted on Nov 29, 2014
Chee Seng
Expert
Level 2:
Answers
284
Questions
0
Helped
163949
Points
706
Maybe the printer ribbon didn't install properly.
Or
Ribbon Base Unit in fault
1 Related Answer
Anonymous
  • 92 Answers
  • Posted on Apr 12, 2010
SOURCE: stop printing test page when installing a new cartridge
It is a test alignment page and MUST be printed in order for the printer to align the cartridges, to avoid one colour over there, another here etc. If it is an all in one, you will need to scan it after it prints. Otherwise, there will be a scanner inside the printing part. There is no way to stop it unless you change the firmware and end up with a printer that can't print correctly anymore.
Just installed new cartridge but blue and red colour is not appearing on calibration sheet..?
Sounds like a bad color cartridge. Start by cleaning the bottom of the cartridge where the ink comes out of with a blank paper until the ink shows on the paper for all colors. If you can't get them to show all colors i would take the cartridge back and tell them it is defective.
I put in new ink cartridge; it doesn't work and keeps telling me it's not properly installed (which it is) and the printer lid won't stay down and so keeps printing off the stupid alignment paper. It won't...
I did recently install a new ink cartilage and now it won't work. I have a small PC and put it on a larger font so I could read it. I am not able to copy downloads due to this change. I was printing after the cartilage was installed but after the font modification, I attempted to print a download by pressing enter, and now I don't see my lexmark icon on the top of my computer screen.I could not get the whole printing page on my Aspire One so I pressed enter.
1helpful
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
2answers
My hp officejet j5750 does not copy
hi im josh in cebu phils.try my solutions
.tt1 {font-size: 10pt;} If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
tip
tip_icon.gif Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
Problem: Your Printer Prints, but the Fonts Aren't Correct If you create a document on a PC with one set of fonts installed, and try to print it on another PC with different fonts installed, you could be in for a real surprise! Windows will try to "match" missing fonts, but quite often the match leaves a lot to be desired—resulting in different line lengths and page breaks than what you had originally. Your options are to install the missing fonts on the PC you're printing from, or change the fonts in the document in question. (A word to the wise: stick to common fonts such as Arial and Times New Roman if you think you'll be sharing a document on multiple PCs.)
Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge.
Problem: Paper Jams in Your Printer It's possible that your printer's internal paper feed mechanisms are getting dirty. You can try taking the printer apart yourself to clean out any pieces of scrap paper or other debris, or you might want to take it into the shop to let a pro deal with it.
You might also be getting some paper sticking to other sheets of paper in your paper tray. (This happens more often with cheaper paper—spend a little more and get the good stuff!) Try thumbing through the stack of paper before inserting it into the tray; this should loosen up the paper and make it feed easier into your printer.
Finally, you might need to change the grade of paper you use with your laser or inkjet printer. Lightweight papers tend to jam up the works, so switch to something heavier if you experience a lot of problems.
THE ABSOLUTE MINIMUM
  • Most printer problems are caused by a bad cable connection, a misconfiguration in Windows, or a bad or outdated print driver.
  • All printers need periodic maintenance; make sure you regularly change toner or ink cartridges, clean the paper path and feed, and—if you have an inkjet printer—use the cleaning option to clean the ink jets and cartridge.
  • If you're having trouble printing graphically intense documents on a laser printer, you might need to add memory to the printer or simplify the documents.
  • Lightweight paper can cause unexpected paper jams; use a better grade of paper to keep things running smoothly.
  • good luck friend
2answers
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
3helpful
6answers
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Paper detection and new ink cartridge
Press the green diamond key on the face of the printer when the error message comes up and it will print
9helpful
6answers
Printer "prints" but when it's done, no ink shows on the page.
When you filled your cartridges were they empty? If so there is a good possibility that the nozzles are gummed and dried up. If you are going to fill them yourself watch the indicator that comes up on the screen it will tell you when you are getting low. If you get a low indication fill it asap. This will keep your nozzles wet and free flowing. Waiting until its empty can cause them to gum up and altimately dry out. My solution is to go to the store buy brand new cartridges. Go through the the full set up that your manufacture recomends. This means using the install new ink cartridge utility that came with your printer. Print a test page and print a nozzle aligment page. Just remember never let your ink completely run out before filling. If you follow this you will never run into this problem again.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
