sounds like the lock out switch on the clutch pedal or the connecting wire to it..not connected means no start especially if left in gear when shut off..check your fuses as well..GOD BLES
If you could please provide me with your model number I would like to be able to assist you further. Typically you can locate your serial tag (which lists your model number) on the inside wall on the left hand side of your dishwasher. One troubleshooting step you can perform would be to disconnect power from your appliance for roughly ten minutes. If that does not work I look forward to receiving further information to assist you. -Matt
is the transmission rod pushed in if not get rear wheels off groud then with pedal press forward force wheel to turn forward while trying to force rod in takes two people to do this but it works if you here whine pump has gone bad have to replace it
I understand that you are asking what the yellow light with a lock button on your Frigidaire washer means. Typically a lock symbol stands for control lock. I notice you did not provide your model number, if you comment back with your model number I would like to research to verify the information. Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. I look forward to your response.-Matt
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Hi, most likely the brakes are hanging up. Follow the brake pedal path to the rear of the mower, it is attached to a small arm on the side of the diff that is probably locked forward. This lever and the pins behind it need to be freed up so the lever operates forward and backward freely when the brakes are applied and released. Hope this helps, regards Phil.
