I have a GE Monogram Wine Chiller ZDW24A RBB. Everything works fine, but today the light stopped turning off when I shut the door. I checked the sensor on the bottom and it seemed to be in order. How can I fix this?
On the right of the thermostat on the grill below the door is a rocker switch, turn it off as this is a light switch not a power to unit. Its just the switch was turned on during your cleaning process. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
The water solenoid valve should have 120v going to it. (You will need a multimeter to chk this). You will need to also chk. for proper ground when verifying the 120v. If you get 120v on each of the pin clips, then your plug is not properly grounded, which means that you need a new ice maker circuit board. This is located in the in dispenser (front panel opens).
SOURCE: GE Monogram ziss480dmss Side-by-side refrigerator
no replace the door control bd or check for a loose or bad connection on the control bd also in an abstract sense one of the freezer door switches could be bad ones for the freezer light ones a safety for the door dispenser sys but that would be rare but possible
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
SOURCE: ge gsl25jfrfbs water disoenser not working
Solenoid or the dispenser switch.
The water supply line connects to a water valve on the Ref. this water valve has two solenoids, one for the ice maker and one for the water in the door. Check this solenoid with an OHM meter.
The dispenser switch should send 110 volts to the solenoid. Check at the solenoid while pushing the water switch in the door.
SOURCE: I have a GE Monogram Wine cooler model ZDB24AABB cooling fan
No switch. Fan motor going bad and must be replaced.
