Question about Mitsubishi WS-48513 48" Rear Projection Television
Green light just blinks
It all started when the picture would become as best i can describe,ie. pixely, when you push menu button it would lage like zoomed in, and would not be centered, also "pixels" would change and move when adjusting volume and volume bar would like blink and be large at times. ok so the tv still worked and one day came home and green light was just blinking and tv did not turn on, unplugged tv and removed backing panel and blew out dust with air, plugged back in green light just blinked we let it blink for an hour and nothing unplugged and left alone for a couple of weeks out of curiosity plugged in watched light blink for maybe a minute and it turned off an dthe tv was fine like nothing was ever wrong, so used the tv for a couple of months then the pixels came back and then the green light just blinked and never stopped, so tried unplugging for a couple weeks and plugged back in and green light just blinked and never stopped for like a whole 24hrs so i just unplugged it and left it alone so thats where im at.
  • 1,694 Answers
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Posted on Nov 22, 2007
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
No picture, just a red blinking light
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Feb 07, 2010 | RCA Televison & Video
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture & sound go off for 1-2 minutes, then return.
The most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Jun 19, 2008 | Televison & Video
Error code 1 2
if it does it again i would check for bad caps
Blinking Problem
replace DM
Picture of bad caps
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-48513 48" Rear Projection Television Logo
297 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
