Question about ViewSonic VA720 17" LCD Flat Panel Monitor
How do I fix 'out of range' problem when I connect monitor to my MacBook Pro
Screen mirrors laptop screen when laptop is open, but when it closes I get a black screen with the Out of Range message on screen. I have tried different screen resolution settings, but still get same message.
    New Friend:
  • 62 Answers
Check to make sure that closing the panel down does not cause the laptop to go into standby or suspend mode. In other words, are you sure that the video signals are not halted by the action of closing the panel down?
Posted on Feb 08, 2015
5 Suggested Answers
SOURCE:
  • 12 Answers
SOURCE: Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
Posted on Oct 15, 2007
SOURCE: Viewsonic monitor VA2012wb is reading ''out of range''
Restart the computer and as it is booting up, tap the F8 key on your keyboard. Choose the VGA mode to lower the resolution for the video card. This will allow you to get in and slowly up the resolution.
Posted on Nov 19, 2008
SOURCE: The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Posted on Mar 12, 2009
  • 225 Answers
SOURCE: Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
Posted on May 23, 2009
Blank screen
Sounds like your screen went bad.
Close the lid, attach an external monitor, open lid and see if the screen appears on the monitor.
Resetting the PRAM may do the trick also:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
Happy New Year,
Kerry
Mar 16, 2014 | Apple MacBook Pro Notebook
My macbook pro wont start and i can hear the noise of the starup but the screen is black
Connect to external monitor to isolate the problem. If you get a picture on external monitor, then you know your screen is fu.k.d up. Since its a MacBook Pro, it might still be under the 1 year warranty, so take it to the Apple store and have them deal with it. If you get no picture on the external monitor, then you know you got a problem with the computer.
Feb 10, 2010 | Apple MacBook Pro Laptop Computer with...
Screen shift when connecting Mac to LCD
When connected to an external display you have 2 options.
Extended you can stretch across both screens like a giant desktop or you can have mirrored displays which have exactly the same thing on each.
With your monitor plugged in...
  1. Open Apple ▸ System Preferences..
  2. Select Displays
  3. Go under Arrangement section
  4. Check the Mirror Displays check box
IF YOU LIKE WHAT I WROTE PLEASE VOTE 4 THUMBS UP!
(any less screws up our average)
Thank You and Good Luck!
Feb 04, 2010 | Apple MacBook Pro Notebook
I have just hooked up an external monitor (LG Flatron) to my macbook--no problem with web pages, but I am unable to see my desktop or any word files. When I boot up, it says analog in the upper right...
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
Aug 05, 2009 | Apple Refurbished MacBook 2.4GHz Intel...
Bump on macbook pro cover
If the bump is on the face (back of the screen) of the laptop there is no easy way to fix it.
Dec 30, 2008 | Apple MacBook Pro Laptop Computer with...
How can i watch a dvd from my mac book pro through an hd tv ,
Open up System Preferences in the Apple menu, then go to "Display".
Make sure the monitor is connected, and click the "arrangement" tab. Check "mirror displays" OR drag the menu bar (white bar at the top of one of the monitor representations) from your laptop screen image to the desktop screen image.
Nov 22, 2008 | Apple MacBook Pro Laptop Computer with...
Electron Blue IV monitor: wrong mirror display with Mac 10.5.5
Is the mirroring still taking place or just on the one display.  If it just on the Macbook, go to the display settings and select the arrangement button, there should be a mirror button there.
Oct 11, 2008 | Computers & Internet
Faint white spots on macbook pro lcd screen
If the spots remain in the same place I'm sorry to say no. Be careful what you clean the screen with. I'm a fan of a warm wet damp only rag. Using alcohol or other cleaners may damage the surface. There are also cleaners available at local stores. You don't need anti-static on an LCD display. The spots can be from pressure on the display applied at some point even if that pressure happens when closing or transpoting your laptop.There is no way to fix it.
Sep 18, 2008 | Computers & Internet
Monitor non functional
Am I correct in understanding that your MacBook is operating properly, but when you attach your external monitor it doesn't show anything?
I often connect my black MacBook 2GHz to my flat screen's VGA port. Sometime the screen doesn't respond for one reason or another. The fastest solution is typically to mirror the screens then return to normal. When that doesn't work, it's usually enough to restart the MacBook while it's still plugged in to the external monitor. If neither of those work, try connecting to a different monitor or finally try replacing the connector.
Unfortunately those connectors don't have the best life spans. (See Apple's customer reviews on DVI connectors.)
iKnow Apple Dan (919) 280-3101
Aug 02, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
83 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
