Improper infrared signal output from the remote control. It might be faulty. Try an other remote control. Electro help
SOURCE: My Olevia TV will not change channels using the remote or buttons
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
