Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
What would cause the oven to only light on broil and not bake. The top burner works but the lower one does not.
  • 11 more comments
  • JAEAC1 Nov 11, 2007
    This is a Kenmore gas range oven. All burners work. The oven only works on broil, not on bake. The top oven burner works, but not the bottom. What could be wrong? How to fix?
  • Anonymous Nov 16, 2007
    I have same problem. removed ignitor it tested good. no glow when in oven was told gas valve or clock bad there was on power at coil when tested with meter
  • Anonymous Dec 19, 2007
    The top four burners work fine but the oven inside doesnt work.
  • fixitifIcan Dec 21, 2007
    had same problem replaced ignitor works now but the alarm is going off flashing F-1 wont srop beeping what to do?
  • scotttee Aug 23, 2008
    Same problem, top burners and broiler work fine but oven wont light. Igniter glows bright and shows no sign of being weak, can't tell it from the broiler igniter. But still, now flow of gas to the oven burner.
  • Anonymous Oct 25, 2008
    replaced controler and gas valve no help
  • fryefamil9 Nov 24, 2008
    top briler is working but the lower burner is not
  • farsateri Dec 02, 2008
    I have kenmore gas stove oven ( model no. 790. 79013100 ) ( serial no. VF 20907912) and lower burner won'nt work but the igniter glows. I would be thanksfull if I get some advise how to fix it.
    farsateri@comcast.net
  • Anonymous Mar 13, 2014
    stove top burners light but oven does not work. this unit does not have electronic ignition
  • Anonymous Mar 14, 2014
    Is there a piglet light for the oven? When I turned it on nothing happened. We have gas
  • Anonymous Mar 20, 2014
    some keys work others do not, burners work
  • Anonymous Mar 26, 2014
    After turning oven on for a few minutes it made a loud pop and then oven stopped working. Bake, broil and clean lights come on an 88 but only top burners of stove work.
    Turned oven on to bake and after a few minutes heard a loud pop and oven stopped working. Top burners work. Bake, broil and clean lights stay on plus an 88.
  • 473 Answers
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 11, 2007
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
Nov 03, 2010 | Kenmore Ovens
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
I can't bake. The bottom burner in my stove is not working. The broiler works fine. Could the burner be bad?
yeah, it's definitely the burner. most people use bake more than broil and that's the reason why bake goes out first, almost all the time. you can check by getting a reading of 240v where the element connects to, assuming this is electric. If it's gas, then the ignitor needs to be changed and you should get 120v reading. Good luck.
Jul 08, 2009 | Kenmore Ovens
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
935 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
