Have dragged the icon from a sd card to desk top now I need to know how to move them to a email or someplace I can then send them this is windows 8 I hate it
SOURCE: Windows expand to full size during drag.
Is it possible that someone has changed the settings on your mouse so that when you click once it double clicks?
Check in control panel for mouse settings
SOURCE: can not send page by email
If you are running Vista,you have a tool called the SNIPPING TOOL,you will find this in the ACCESSORIES folder in the start menu.The snipping tool is a fantastic utillity.I suggest you RIGHT CLICK on it in the Accessory folder and select add to "QUICK LAUNCH" Which is the 2 little arrows in the bottom right hand side of the taskbar,this will enable you to use it quickly,you could also create a short cut to the d/top. What this tool does is lets you take a snippet (photo) of what ever you wish on the screen. When you have the required "snippet" click the save icon (top left of snippet screen) and choose where you want to save the Snippet to. I Created a new folder in my Pictures File Purposely for my snipetts. I hope you find this helpful,if not i will be happy to find another solution for you. Happy E-mailing.
SOURCE: task bar still not found dropping & dragging
I sugest you you change to clasic so that the taskbar is reseted and the ten restart an do allthis again and change it like it was. You can also bbot in safe mode, by tapping F8 @ boot screen and change the setting there when you restart it should be OK
SOURCE: Can I upgrade the 8 GB SD card to a 16 GB SD card?
You should be able to use any size SD card you want to.
SOURCE: how can i transfer music from my pc to my sd card?
open up mycomputer and open up the folder that houses the music, then open up a mycomputer again, and open up the drive with the SD card in it. now resize both so that they are sitting side by side, click on the song you want and drag it over to the SD folder.
there are other ways, but this is a easy way for a beginner.
