Thank you for your inquiry, friend!
Based off the information you have provided your Frigidaire dishwasher is locked and will not start. I would suggest a reset on your appliance that may release the lock on your dishwasher. To reset your dishwasher you can flip the household circuit breaker off for ten minutes.
If that does not help correct the problem it could be an issue with your control panel or faulty wiring harness. Hopefully this has been helpful. -Matt
SOURCE: Dishwasher Problem
According to my ultra wash dishwasher you have to hold the no heat dry button for 4 seconds and that is how you lock and unlock the control panel
SOURCE: led wont light up. no power to dishwasher
Measure for 115 volts AC at the junction box behind the front lower panel where the incoming power connects to the washer wiring. If ok, you will need a wiring diagram of the washer to go further.
SOURCE: frigidaire from Electrolux dishwasher, model
Press and hold the Heat Dry button for 10 seconds or so
SOURCE: Hello, We own an electrolux EX600ISB*01
In order to fix you unit if it is not under warranty you would remove the screws that go along the inside of the door panel that hold the two doors together in order to access the lock assembly area in which you can then watch how the lock is supposed to go into the hasp clip in order to assure that the lock is opening as well as staying in the lock position on some units there is a switch that is connected on the door lock assembly but I do not see the switch being sold seperatly on this unit click here for part information on the door lock assembly http://spares.bigwarehouse.com.au/product_info.php?manufacturers_id=&products_id=1611139
if you take the door apart you might be able to see the switch for the lock assembly and also may be able to reset the switch or put it in its proper position which may fix your issue or you can order a new lock assembly usually when i do fix a lock assembly I also replace the hasp as well due to not knowing if someone when they noticed the door wasnt shutting correctly leaning or pushing the door close and bending the hasp as well If you have any further questions message me back I await your reply Thanks Rick
SOURCE: electrolux 5505 dishwasher will not come on - no lights, nothing
Hello Kathy Prussack - I understand you said there are no lights on, however try unplugging the unit or flipping the household breaker off for two minutes to reset. Is there power to the unit? I suggest touching each button individually on keypad, does any lights turn on or does display change? If not, I would recommend contacting a professional because the unit may possibly have a defective keypad.
Good Afternoon Pina c, thank you for your inquiry!
I understand that your led power light is not displaying once you open the door on your Electrolux dishwasher. If you are having an issue with an internal light it could be a blown bulb or an issue with the receptacle. If you are having an issue with your control panel not lighting up it could need to be replaced. I would recommend having a technician out to your home to exchange any replacement parts. Hope this information is helpful. -OOS
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
