SOURCE: SpacemakerXl Microwave Oven JVM1650/1651
The magnetron may be failing or overheating.
There is a known issue with many GE models.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: I have a GE SpacemakerXL
Thanks for the opportunity to help! To see if this fault can be cleared, do the following:
*If your unit is hardwired, find the circuit breaker and turn it off for 30 seconds, then turn the power back on.
If you find my assistance helpful, please rate my service. Thanks for using FixYa.com
SOURCE: I have installed 2 new light bulbs in my GE
We see (and repair) this a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at
our Web site, along with a video showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
When there is no heat, but everything else seems to work, it means the magnetron circuit has failed. The magetron is the part the generates the microwaves that heat the food. When it fails, it makes a loud buzzing sound. The replacement part can cost as much as a new oven, so it not worth fixing. Get yourself a new oven.
