Question about Philips Magnavox 20MT4405 20" TV
Magnavox 19prc1 0121
The Horizontal hold jumps in and out. I can't find an adjustment. Granted I'm from the era when there were pts and a screw on the back. Can you help me.
Jeff.
    President:
  • 2,992 Answers
There aren't any adjustments anymore. This can happen as parts inside age and values change. Also solder connections can fail over time and cause problems. The problem you describe can be in any of several areas of the set. There really isn't anything you can do yourself to repair this. If you want to keep the TV you can get an estimate for repair, but this might be a good time to check out sale prices on new TV's and think about replacing it.
Posted on Dec 16, 2008
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
How do I adjust the fill valve on a Jaccuzzi Era toilet?
If it resembles a Fluidmaster unit, twist it clockwise to decrease the float height. You may have to flush and recheck the setting to get it just right.
Jul 20, 2017 | Jacuzzi Bath Era BK37 959 White toilet...
Locating the horazonal hold control button on a magnavox 19inch tv modle number 19pr14c225
old models had small Pot for adjustment the horizontal+vertical etc
Newer model doesnot.By that reason you will NOT find it.
I am sorry.
if you have some problem you must go to the repair shop TV.
God bless you
Jul 31, 2012 | Televison & Video
Magnavox model# RJ8550AK03 I need the part# for the horizontal output transformer located onthe defection panel.It is not a fly back more like low voltage supply .Where can I buy one?
I believe the part number for that is 003620020003 , but I believe it is a NLA item. Your best bet is to get the complete module off of another used tv, or contact the repair module companies like PTS electronics or tristate module to check their stock, they might have a rebuilt or a leftover transformer, who knows, try ebay, there is all sorts of things for sale over there. Good luck!
Feb 06, 2010 | Philips Magnavox 9P6034C 60" Rear...
Jacuzzi Era elongated seat attachment
first need to buy the longer oval seat so it sits correctly at the front most mounting screws are universal-- go buy thin rubber washers and trim and place between the hinge and bowl than tighten down this will stop slippage but the front if not correctly sitting on the bowl will still cause problems
Jan 22, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
How do I adjust the headlights. I just bought
Generally on headlights, there is going to be 2 adjusting screws. You can tell them because they don't match the other screws holding the headlight in place. If you need to take off the outer ring to gain access to them. Stand the bike back around 30 feet and draw a horizontal line in tape ( usually against a garage door ) approx, 36" from the ground. Line up the headlight with that line and you should be good to go. 1 screw is generally a horizontal adjustment and the other is a vertical adjusting screw.
Aug 28, 2009 | 1998 Honda VT 1100 C3 Shadow Aero
Adjust headlamps 99 contur
Headlamp Adjustment Alignment
  1. NOTE: All adjustments should be made with headlamps off and at room temperature.
    Prepare the vehicle for headlamp adjustment.
    • Place the vehicle on a level surface.
    • Before aligning the headlamps, check them for faulty lenses, reflectors and blackened bulbs, and install new components as necessary.
    • Check the tire pressures and correct as necessary. For additional information, refer to Section 204-04 .
    • The vehicle must be unloaded with the exception of a tool kit and spare tire. The fuel tank should be half full.
    • Bounce the vehicle several times both front and rear or roll it a few meters so that the suspension settles.
  1. Locate the headlight adjustment screws.
    1. Vertical adjustment screw.
    1. Horizontal adjustment screw.
  1. Adjust the horizontal headlamp screw until the Horizontal indicator aligns with the "0" reference mark.
    1. "0" reference mark.
  1. Adjust the vertical headlamp screw until the bubble is centered.
    1. Bubble level indicator.
Jul 04, 2009 | 2000 Ford Contour
Magnavox tve244239
There are vertical and horizontal adjustment in the tv, however it requires removing the rear cover.
If you are unsure of the adjustments rather let a qualified tech service the tv for you.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 20MT4405 20" TV Logo
277 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
