Question about Dual XDM-6820 CD Player
Display comes on then cuts completely out
When i first start car the display comes on but cuts out after a few minutes.
u can still make out whats on the screen but u have to look close.
  • eml29xo Jul 03, 2008
    when i turn on my car the display on my player doesnt light up you can still read it but you just have to look really closely.
  • pankajt Sep 04, 2008
    Same problem as he mentioned... display cuts off
Hello. here is the solution...if you still need it..
Open up the face plate... by unscrewing the 4 screws at the back corner of the faceplate
Expose the PCB with the LCD display mounted on it...
towards the right is black tape... remove the tape.
this exposes 2 White LED ( 3 mm) tapering inside the cavity of the LCD display..
If the symptoms are what u say... then the LED's are dead...
Unsolder the bad LED's with new ones.... and then fix everything back
hopefully everything works.. Cheers.
Posted on Sep 11, 2008
When I start my Frigidaire FGMV174KFB microwave oven it shuts completely off and after about a minute it comes back on and does a factory reset. Any suggestions on what I should do to fix?
I appreciate your inquiry, David!
From the information you have provided your Frigidaire microwave shuts off and then will factory restart. It sounds like a possible problem with your control panel or a faulty wiring harness. I would recommend seeking assistance from a professional. They would need to properly disassemble your microwave and test each electrical component to pinpoint the problem within it. The technician has the appropriate tools needed to complete the repair without causing personal injury or any future issues with the microwave. Best of luck! -Matt
Mar 16, 2015 | Frigidaire Microwave Ovens
A/C fan cuts out completely when on high fan AND recirculate
Replay the blower resistor. Used to be you could replace the relay, but they are built into the resistor now. Should be under the passenger side dash. Usually behind the blower. There will be four to six small wires going to it and two big wires coming from it going to the blower motor.
Jul 13, 2013 | 1996 GMC Yukon
Cuts off shortly after turning it on
Sounds like you have a short some place, and it needs to be replaced.
Dec 25, 2012 | Hamilton Beach 33966 6-Quart Slow Cooker
2003 Envoy intermittent display, radio, ac control, shift, comp.
This sounds like your alternator maybe going bad. When your alternator starts to go bad lights such as headlights, radio lights will go dim wipers will start to move slower but if you cut one of the things off such as the wipers the lights will get brighter for a few minutes then not long the car will shut completely down. Hope this helps.
Jul 22, 2009 | 2003 GMC Envoy Xl
Letters EE came up in display, and it cut off! now, not cooling
The problem is in the electronic control. I have reconfigured these in the past using older style controls and had some success.
Jun 12, 2009 | Heating & Cooling
IBM T40 2373 display cuts off.
When it cuts out can you still see the display very faintly or does it just go completely black?
Mar 10, 2009 | IBM ThinkPad T40 2373 Notebook
92 sc 300 stalls
replace your fuel filter if there is one if not, then replace the fuel pump, filter was attached unto it.
Nov 21, 2008 | 1992 Lexus Sc 300
Sound cuts out every so often when using Coax Digital In
DI cables have little end caps, make sure they are removed
Mar 04, 2017 | Audio Players & Recorders
solution to Both our problems is this, call Philips, "it just so happens that we have a rapid replacement program for this particular system"-"there seems to be an internal electrical problem", so I'm sending it back to them.......
Dec 12, 2007 | Philips HTS-3555 System
Dual XDM-6820 CD Player Logo
214 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
