Question about Frigidaire FEF336BC Electric Kitchen Range
Setting the correct time on the clock
We just moved in to a previously owned home and it has a Frigidaire Elite Range with the ceramic top and convection oven. We can not figure out how to change the time on it! Please Help! We didn't think we were this technically challenged!!
  • 2 more comments
  • Jayne2000 Nov 11, 2007
    Thank you so much! I knew it would be something simple like that. The symbols on this range are not that straightforward. It's hard to tell between the timer and the clock symbols. I now know that the " " : " " is the clock!!! lol
  • lanaleeb Feb 08, 2008
    I can set the clock on my range but when I open the oven door the clock goes back to blinking 12:00 and I have to set it all over again. The clock does not seem to stay set.
  • Anonymous Mar 03, 2008
    Jayne please help. We have to put tape over the blinking zero's. I'm so desperate. My e-mail is . Thanke you!
  • fixingirl May 11, 2010
    Hi there, My parents have a Frigidaire Elite Range Type 3S1 Model #
    RE645501. The problem they are having is setting the clock.Their
    instruction manual is for a different clock. I can take a picture of
    it to aid you further if needed. Thanks
  • 473 Answers
If you could send me a picture of the control I can show how to set the clock for sure. Usually on frigidaire you will hold down on the clock button (may be a picture of a clock) until it blinks and use the up and down arrow buttons to change the time. When the time is set hit the clock button again.
Posted on Nov 11, 2007
Setting the clock it is a frigidaire elite stove
Hello Susan, thank you for your post!
I understand that you need help setting the clock on your Frigidaire range. Could you provide me with your model number please? You should be able to locate the serial tag (which lists the model number) on the frame behind the bottom drawer. With this information I can better assist you. -Matt
Mar 13, 2015 | Frigidaire Ovens
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
How to reset clock when daylight savings ends?
Hello Fran Addington, thanks for your post!
I understand that you are having difficulty setting the time on your Frigidaire range. With some ranges once you press "Clock" the time is actually set using the keypad with the numbers. I would attempt to use the keypad. If that does not help correct the issue could you please provide me with your model number? Typically, you can locate the model number on the bottom panel behind the drawer. I look forward to assisting you further. -Matt
Nov 02, 2014 | Frigidaire Kitchen Ranges
I have a ceramic top slide in range. The clock will light up when the clock button is pressed but will not stay lit. Timer works and all oven controls work as well as the cook top and oven. Any...
Hi Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing, it appears your Frigidaire range is possibly experiencing a potential wiring failure or a communication problem with the EOC (Electronic Oven Control). Try unplugging your range or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and then turn on your range. If the issue continues, then I recommend contacting a professional to make a precise diagnosis.
May 21, 2014 | Frigidaire 30" Self-Cleaning Slide-In...
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Clock dispplay not displaying
Hello jenniferp702 - Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately two minutes and turn on the range. Attempt setting the clock, if it is ineffective then I would suggest contacting a professional to move forward accurately. The range may possibly have a faulty wiring or a communication issue with the EOC.
Oct 10, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do I chance the time on Frigidaire Gallery stove, to move it ahead one hour
Press clock button, then press temperature up button. Time will begin to change. When you have the correct time set, press the clock button again to save.
Mar 13, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Some Ovens Control Buttons Don't Work - Frigidaire PGLEF385B
although you cannot see damage / the when the buttons do not respond. its possible that membrain is damaged or the eoc ( clock ) is not able to receive signals from the touch pad .. the clock will have to be replaced . list price for clock is 171.00 and includes membrain ( touchpad) .. hope this will help mm
Dec 03, 2009 | Frigidaire FEF376 Electric Kitchen Range
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Replace ceramic top on gas range
yes the part number that you need to order is 316251903
Apr 13, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
1,567 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
