Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Dishwasher stopped working
Maytag Performa dish washer just stopped working, About an inch of water in bottom of machine, no lights or power on panel, checked breaker its ok. None of the buttons will work Help
Re: dishwasher stopped working
Fixed it - this week - turrns out the power wire under the front was corroded in the plastic joiner - on pushing the wires around , the light flashed on and off- re connected and tightened the connections - I guess over time with the vibration and some
humidy issues the connection was at issue -
so, take off the bottom front panel and jostle the wires a bit and see if it reacts.
Posted on Dec 15, 2007
    Problem Solver:
  • 10 Answers
You have a board problem it came from a power surge.
0 characters
3 Points
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
Maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Sep 13, 2009 | Bosch SHU9915UC Dishwasher
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
My Maytag Performa recently stopped washing the food off the dishes. It fills and drains like it is supposed to, but seems to not have the right pressure.
Before drawing any serious conclusions check wash arms for blockage in spray holes, < possibly slowing delivery of water pressure > it can be calcium from hard water.
Apr 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Maytag dishwasher cannot choose cycle on light panel
hello hmm ok so no lights it sounds like your control panel after unplugging your dish washer check the panel for loose wires the panel is the part behind were your buttons are located will have to remove your back cover to access this if that's all good then try your power cord again make sure its not got any loose wires were it attaches into the dish washer have a nice day and good luck let me know if you find anything.
Mar 19, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dish washer doesn't drain, and control board only blinks
sounds like the control board is faulty. i would suggest having a technician replace it.
Sep 13, 2008 | Dishwashers
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
283 people viewed this question
Top Maytag Dishwashers Experts
Michael Thomas
Michael Thomas
Mike Cairns
Mike Cairns
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
