How can we get this to work???
SOURCE: zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
SOURCE: haier drain tube keeps popping out during/following drainage.
Hello cccookies:
I had the same problem with my Haier (same model). My solution was not very elegant, but it worked:
1) Drain washer + tube and ensure they are completely empty (no water left inside).
2) Remove drain tube and wipe connecting part dry.
3) Wrap duct tape around the part onto which you would normally stick the drain tube. This will make it harder for the tube to slip off. (Make sure that the opening is not obstructed by the tape.)
4) Put back drain tube + metal clamp.
5) Use some more duct tape to connect the exterior of the washer to the drain tube, and vice versa. If you use white tape, it won't look quite as hideous, and you will still save yourself trips to the laundromat.
6) Always monitor washer when in use.
Hope this helps!
