My 39 inch vizio model M4011-A3 has red blue and grey black lines on the left hand side show half of screen.
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
6 pin socket
6 pin plug
7 pin
socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug
& socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin
round plug & socket
1 left hand turn - yellow
2 reverse -
black
3 earth -
white
4 right hand turn - green
6 stop - red
7 tail, clearance, side
markers - brown
round socket
large 5 pin round plug & socket
3 earth -
white
5 right hand turn -
green
6 stop - red
markers - brown
large 7 pin
round plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
7 pin round
heavy duty plug & socket
1 earth -
white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
5 right hand turn -
green
6 right hand rear , clearance and marker - brown
7 reverse/auxilary -
blue
7
pin flat plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
flat socket
12 pin flat
plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
8 battery supply -
orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
