Question about iRiver H10 MP3 Player
<!-- from fixya rte -->How to restore missing files to H10 series - iRiver H10 MP3 Player
SOURCE:
SOURCE: Missing system files
how reinstall the firmware for E10? the laptop doesnt see the HD of E10.
Posted on Mar 24, 2007
SOURCE: iriver (h10)
either find rockbox or iriver plus and do a firmware upgrade
Posted on Nov 19, 2007
SOURCE: iriver H10 "System files missing".
Okay, my IRiver broke with the same kind of problems but I've managed to fix it!
First off i connected the IRiver to the pc, and whilst it was connecting, pressed the 'select' button (the one on the front with the circle on it) to force it to connect.
Next i right clicked on it and selected format to wipe everything off it (just to make sure it was blank).
Next, go to www.iriver.com and on the left hand side click Support->Download and click on H10 in the product box. On that page should be a file to download called "[MTP]H10 5G/5G Pure/6G Firmware Upgrader/Recovery Tool(US & EU only)". The download icon is just underneath the title of it, so download, unpack using winrar ot winzip etc, then double click and follow the instructions.
It wiped the songs off, but i have an IRiver that works! Its an awful product in my opinion, but better to have it working than not. Can't guarentee that it'll work for everyone but it fixed mine first time.
Hope it helps!
Posted on Oct 20, 2008
SOURCE: iriver h10 when switch on it shows system file missing connect h
I'm not sure my solution can help you or not.
I've got this message too but after I formated H10 by Windows.
First backup all files by window explorer.
Open iriver plus and go to > Option > Portable Device Initialization.
This function will delete all data, Please sure that you already backup all of your data from H10.
After initialize process finished, it will ask you to disconnect and connect it agian.
------ Steps below, I can't explain it clearly. May be you will not have the same results as me. I hope it can rise you some ideas how it comes.
I followed that instruction but after I disconnected it again and turned on, expected that msg will disappear, IT's NOT! a bit freak out.
Ok claim down,
I tried to turn it off but I can't then I pushed its battery out and put it back and turned on, that msg showed up again.
Then I connected H10 to Iriver plus again and it upgrades firmware automatically.
At the end after I disconnected and turn on my H10 it works perfectly.
I'm not a native English so my language could make you confused, any questions you can contact me. :)
Posted on Jul 28, 2009
Testimonial: "hiiiiiiii thank u for helping me really i was screwed up but know its working and about ur english is perfect bye ."
SOURCE: I need to restore the system files for my H10 Iriver MP3 player
System Files Missing
To restore
the system files,
connect H10 to
recovery tool.
Posted on Oct 28, 2009
System files were missing
plz tell me how i can restore iriver h10 4gb i can on my mp3 plyer then i read screen he tell me system files missing u can restore but how i can restore plz tell me?
Mar 19, 2010 | iRiver H10 MP3 Player
I reformatted my iriver player, and now it shows system error. what should i do?
Sir/ madam
good day.
me i ask regarding my iriver H10
the problem is system files missing
how to restore the system files connect H10 to iriver plus?
thank u?
Feb 19, 2010 | iRiver H10 MP3 Player
Restore the system files, connect H10 to recovery tool
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Feb 24, 2009 | iRiver H10 MP3 Player
Iriver, H10 , system files missing
iRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Sep 16, 2008 | iRiver H10 MP3 Player
IRiver H10 - System files missing
please, my new iriver h10 is not open. it will say "System files missing"
Aug 03, 2008 | iRiver H10 MP3 Player
H10
Male sure you have the Vista drivers/updated software from iRiver website
May 24, 2008 | iRiver H10 MP3 Player
IRiver H10-
What you need to do is set it on "Disk Mode" and check the firmware. Most problems like this occur due to missing or added files on to your firmware files. This corrupts the entire system, causing it to have strange malfunctions like yours.
don't panic!
bananaboy101
Dec 12, 2007 | iRiver H10 MP3 Player
H10 6gb
to restore system files
Dec 09, 2007 | iRiver H10 MP3 Player
Iriver h10
Get recovery tool from iRiver website
Sep 06, 2007 | iRiver H10 MP3 Player
Iriver H10 saying system Files missing
Try doing a format via windows explorer. Right click on the drive and then format as fat32. Then unplug and open iriver plus. Reconnect. See if that works. Good luck!
Jun 29, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
83 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
