Washing Machines Logo
Asma Jafri Posted on Jul 05, 2009
My washer machine's motor is not running - Washing Machines
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
1548
Points
19
First, as silly as this sounds, check to see if it is plugged in, then check house circuit breaker and make sure it isn't tripped. If you don't hear ANY noise when you turn it on, then problem is either power or the motor is fried. Short of the plug in wall and circuit breaker, any attempts at accessing the electrical board or replacing the motor should probably be done by a professional. In either case, it sounds like you will need a service call.
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
tip
Washing Machine Motor Coupling Repair
How do you tell if your washer motor coupler has gone bad? Motor couplers are used on "Whirlpool" direct-drive washing machines. In some Whirlpool or Whirlpool-made washing machines, the motor coupler connects the drive motor to the transmission. It operates under extreme conditions and stress. Mostly during start-up and stopping of the motor. The main symptom of a bad motor coupler in the Whirlpool made washing machines is that there is no agitation or spinning action, along with the sound of the motor running. Since the motor is running, but there is no connection to the transmission, the machine will not agitate or spin the clothes out. The motor will simply run, but nothing else happens. In this case, the coupler is most likely cracked. To replace the coupler in the Whirlpool made washer, you must first unplug the washer, remove the top console by either removing the screws or using a putty knife to unsnap the top clips, rotate the console back, pull the washer front off by tilting back,and set the cabinet aside. Remove the clips holding the pump and motor on. Remove the bolts holding the motor on. Inspect the coupler and replace with a coupler if necessary. Re-assemble the motor and pump assembly. Re-assemble the washer in reverse order of disassembly. Plug in and test by running the washer through it's paces.Here is a video on repairing the motor coupler.
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Lr message
THIS WEBSITE IS VERY USEFUL FOR YOUR MACHINE
http://www.applianceaid.com/neptune8.html
HERE IS THE OUTLINE FOR THE CODE LR
Lr Locked Monitor Rotor Based in signal information from motor control board, the machine control board senses the motor is not turning when requested to run 1.Run motor control board diagnostic test. 2.Check motor control board for damaged components.
3.Check wire connections in harness leading from machine control board to motor control board.
4.Replace responsible component.
Washer runs but wont adgitate
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley
Washer motor runs. washer drains. washer still
The spin-tube assembly needs to be replaced.
This is one of those jobs to call-in the repair professional for.
4helpful
I am looking for a washer motor for an old gibson stackable washer....but they discontinued the part!
These guys have motors for most machines, bot sure what motor your running. You need to get the model number off of the placard on the motor, give them a call if you have any other questions. Here's the link:
http://cgi.ebay.com/Washer-Motor-134172800,-131902800-fits-Gibson_W0QQitemZ280341079838QQcmdZViewItem
WHAT IS F-6 MESSAGE
Check Wire harness connections between the Drive Motor and the Motor control and between the Motor and the Machine Control
The Drive Motor is fauilty
The Motor Controller is fauilty
sorry if you still have a warranty call for service
Top Washing Machines Experts
john h
