ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
I did the same thing... I found this & IT WORKED!! the URL is http://www.blurtit.com/q1652331.htmlit's super easy & only takes a second to do. Hope this helps. Blessings. -~myleshigh
If your phone is set to lock, and you have changed the Nam, you will have to take your phone to your provider so that they can read the lock code for Nam 2 and change it back to Nam 1. You may want to call them first, they might have a standard code that they use.
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345. Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
The lock code should be the last 4 digits of your phone number or 0000.
If that doesn't work, perform an activation by dialing *228 send. Then select option 1. After this is complete your phone's lock code should be reset to the last 4 digits of your phone number.
hi sir
have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the NAM, you must enter the special access code currently programmed into the phone. Once the programming mode is accessed, NAM parameters are loaded by entering them into the display and "storing" them to selected memory locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10 digits are entered an error message will prompt you to reenter the number.
5. Verify the display reads "Enter code" and enter the five digit SID followed by four zeros. (Example 001750000 is a SID of 175 followed by four zeros). An error message will display if an incorrect entry is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new language code after the code. (Example: 001750000#2. Language = 2)
Change the Lock code and Language code by separating each set of numbers by a pound sign. (Example: 001750000#7788#2). The SID = 00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
i switched my samsung hue from NAM 1 to NAM 2 and my phone turned off automatically.I had my phone set to lock on power up and now i cannot figure out my unlock code.
