Set to turn on from printer only or laptop when plugged in. Automatically turns on with no input.
SOURCE: Automatically prints
Print the test page and place it into the scanner, remember to place the paper in the correct direction. Then press the start scan button on the printer. Let the scanner do the scan and if it is successful, the printer is ready for use. If it failed, then the orange led for check paper will flash slowly. If every thing is done in the correct sequence but get failed from time to time, then you may need to get the scanned image of the test page to see what the scanner is seeing.
SOURCE: warning up
Hi , The printer might have problem with the Power adaptor , If you have one try replacing the adaptor.
SOURCE: computer automatically restarts when I turn on the
plug out the printer...then restart the computer....uninstall all the printer related drivers...
connect the printer and again install the drivers for your printer....then try using your printer ...
it should work fine.
SOURCE: printer won't load automatically when plugged into
Go to www.hp.com. Let the website detect your printer and load the drivers automatically.
SOURCE: after trying to turn on it shuts off automatically
contact hp support they will be able to help you http://welcome.hp.com/country/uk/en/support.html
