Acer PH530 DLP Projector Logo
Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to start my projector when connected to laptop? '
Anonymous
Level 2:
New Friend:
  • Expert 144 Answers
  • Posted on Feb 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
144
Questions
0
Helped
57847
Points
221
Turn on the projector and laptop and connect the vga cord to the projector and the laptop (making sure there is a secure connection so it is tight but not overtight) and hold down function when your operating system has started (windows only mac is different) and press either F1 F2 F3 F4 or which ever one has the picture,icon, of the laptop and the external display.
Projector starts, goes into search mode with a laptop plugged into it, but does not connect with the laptop.
Try looking at your screen resolution settings on your laptop. For Windows right click on the desktop screen then click screen resolution, or display settings and see if the projector is recognized on your laptop. If yes try changing the resolution as the laptop may be trying to connect at a resolution that isn't supported by the projector.
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
No image appears on the screen
type 'projector' on the start menu.it should show you the option to connect to a projector,some laptops need you to press f8 to connect.
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
I have a Hitachi LCD projector model No. CP-RX70. When I connect with my laptop (Compaque) and start both then only starting window XP message appears through projector and laptop works normally but again...
The setup is not correct. Check the requirements of the projector, (size, refresh rates etc.) and set the laptop up accordingly.
You will se the XP Screen because the laptop hasn't loaded any drivers yet and the screen is low resolution.
Hope that helps.
2helpful
2answers
How do I connect a projector to my G60
Hello
  1. Start by making sure the laptop and projector are both turned off before you start trying to make any connections.
  2. Locate the video cable -Usually your computer should have a svideo ort out. The projector should have either a hdmi or a RCA immput ports, thus you need a svieo to rca cable. Otherwise your laptop should have a VGA port oout where the projectorr should have a VGA port in.
  3. Make sure both ends are securely connected and tighten if necessary. Use a screwdriver or small pliers to tighten the connectors. A loose connection at either end will prevent you from displaying your presentation.
  4. Locate the audio cable and connect the audio cable included with the projector to the Audio Out on the laptop and Audio In on the projector. Make sure these connections are tight.
  5. Start your laptop and the projector. Make sure to check all connections to ensure they have been properly connected.
Really hope this can help you.
Kind regards
Andrea
2answers
Dell 2400MP out of range with vga connection
make sure that the resolution matches and that the laptop and the projector are both on vga and not composite. you can also reset the projector settings to factory default to start from the beginning.
3helpful
PJ551 won't connect to laptop
Use your function key (Fn) and press F8 (CRT/LCD). This will tell your laptop to switch to projector mode.
Hp vp 6210
connect the laptop with projector and power up the projector and select the input 'computer' now start the laptop. the Projector will automatically detect the signal. secondly also chek with the display setting set to 800x600 then check with higher resolution.
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
