My garmin will not talk to me and give me the directions. I checked the volumn and it is at 100%
Get the Garmin Express program: Garmin Express
watch this video:
Then go to tools and find the voices portion. choose your language, install at the bottom and then check to make sure your Garmin has a voice chosen. if it does ... check to see if the device beeps and that mute is off. and if it does not even beep then you must have a bad speaker
SOURCE: Voice directions not working.
First, ensure that you are using the unmuted internal speakers by pressing the power button twice while the unit is on.
Do you hear beeps (button tones) through the speakers?
These are a couple things to try:
1. Change the voice from English TTS (JILL) to English TTS (JAKE) - This will demonstrate whether the voice database has been corrupted.
2. Tap the power button twice while the unit is on to switch back to fm transmitter and attempt to use your radio to tune the sound. If you succeed here, you may indeed have a problem with your internal speaker. A return of the product may be necessary.
SOURCE: garmin nuvi won't talk
Go to Tools|Settings|Language|and change it to "American English (Jack or Jill) TTS).
SOURCE: my garmin 750 quit talking??
Please see this link on how to restore the TTS voice directions:
http://www.sharc.net/discus/messages/6/74.html?1252801589
- Jim
SOURCE: Had Garmin nuvi 765 installed
There is a slight possibility t could be a faulty or loose wire. You can check. But it also is common in for some newer units that have lots of shelf life on them to need a software update which can be found on manufacture's site and some others as well. Many youtube videos with directions on how to update these units.
SOURCE: Garmin Nuvi won't talk. No sound when programming
If the mute is not checked, try plugging in a set of headphones. if you now hear sound, your internal speaker is blown. Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
