Husqvarna chainsaw replacing crank shaft bearings. How do you take the second bearing off the shaft? Cannot seem to remove.
SOURCE: instruction to remove and replace cage bearing on
I guess we are talking the bearing in the clutch drum, to replace this you need to remove the side cover nuts and remove the side cover/chainbrake, make sure the brake is de activated by pulling the hand guard fully back to the top handle before removing it, the clutch has a 15mm centre nut, jar the clutch off against the compression of the saw with a suitable socket and speed brace, if you have an impact wrench this will remove the clutch in seconds, the clutch is just spun onto the crank with a left hand thread, turn clockwise to remove, once off the drum and bearing will just come off the crank for replacment.
