Question about Pioneer DV-F07 DVD Player
Vertical lines moving from right to left at about 60 cycles
I have vertical lines in my DV-F07 dvd player, moving from right to left at about 5* right offset from vertical and at about a 60 cycle speed
I have a B & K system with Mirage Shieiled spekers, HD projector, monster power HTS3500
1.) I have changed dvd location
2.) I changed component cables
3.) I use clean power from monster HTS3500
4.) I have taken the DV-F07 to a friends where F07 worked perfectly
5.) If I plug in a cheep DVD lines go away
Can you help me
  • ricky perry
    ricky perry Nov 11, 2007
    I also added grounding straps to all components, and still no change to vertical lines
    Problem Solver:
  • 4 Answers
Probably solved long ago, but this sounds like RF interference. Is there a radio or television transmitting site within a few miles of your location? Or it could be the projector itself causing interference to the circuitry within the player yet not be a problem with any other source. Try it with another TV with the projector on and off. Even a small black and white will do.
Posted on Nov 13, 2008
I cant stop the tv monitor screen from jumping it has something with the dvr
Hello What type of TV do you have, analog or digital? If you have an analog TV and the screen is rolling it is the vertical hold. Because the vertical hold operate on 60 cycle which the same as AC line cycle. The 60 cycle in the vertical hold is as a oscillator or timing circuit. When the TV pick up the image for the NV devise, they just don't mix. Why, because image intensifier tube in the NV devise is operation at 25 to 50K Hz or cycles. The vertical hold circuit pick up on the 50K Hz signal which mixes with 60 cycle timing circuit causing the screen to rolling with lines across the screen @ 60 cycles. Digital camera and digital camcorder with digital TV will help, or a image inverter that takes this 50k Hz signal and covert it to some that analog TVs can use. GB...stewbison
Jan 18, 2011 | Optics
How do you hook up this dvd player to the tv. the plugs are blue green and red instead of white yellow and red
The DVD player has component video as well as the S-video and RCA video and two RCA audio outputs.
If your player is the same as my picture, the component video jacks are in a horizontal line at the top of the back of the player. The white and red audio jacks are in a vertical line to the left. The yellow video out jack is in the second line just below the component video jacks (in a line with the coax port, the S-video port is in between the coax and the RCA video out). (The white jack is at the top left of the connections block, red below that, and yellow to the right of the red.)
I hope this helps.
May 29, 2010 | RCA DRC247N DVD Player
How do I enable this player to become multi-region? I believe it's based on a Pioneer rather than one of Teac's own designs.
Thanks for using FixYa. To make it multiregional please follow these step by step instructions using your remote control:
1. Switch power on
2. Open the DVD tray (leave it open with no DVD in it)
3. Press "stop"
4. Press "734466"
5. Use cursor to scroll up or down until it says "Region 0"
6. Press "OK/Enter"
7. Switch power off
8. Switch power on
It show now play all region DVD’s. Please do accept the solution if the issue is resolved or else revert for further assistance.
Jan 30, 2010 | Teac DV-H500 DVD Player
How can I unlock Sharp DV-SL2200W
To unlock your DV-SL2200W player follow the below instruction.
1. Switch the player on without disc
2. Using the remote control press "HOME MENU"
4. Select "OPTION" on screen
5. Press "OSD" button
6. Press buttons, 3,5,7,0
7. The player will automatically shut down
8. Switch the player back on
Now you player will be Multi Region.
Sep 05, 2009 | Sharp DV-SL2200W Player
1. Open DVD tray.
2. Entre 0520 using remote.
3. Press keys in this order: UP, DOWN, LEFT, RIGHT.
4. Enter region code, 0 for complete code free.
5. Close DVD tray.
May 26, 2008 | Daewoo DV-6T955B DVD Player/VCR
I own three Pioneer DV-F727, I wanted to know is it possible to daisy chain all three?
I don't think the software will support this configuration as far as control is concerned.
Apr 29, 2008 | Pioneer DV-F07 DVD Player
Green line on TV with DVD playing
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Mar 07, 2008 | Philips HTS-6500/37 System
Door won't open and turntable does not turn
unfortunately you may have to reset the unit. This will cause you to lose everything saved in memory so make sure its not just a DVD stuck in the mechanism. To reset to factory default turn unit off then press and hold Stop and press Standby/On
Dec 08, 2007 | Pioneer DV-F07 DVD Player
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
Multiple vertical colored lines on DVD player screen
check this out
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Pioneer DV-F07 DVD Player Logo
93 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
